Pagina 112 di 316 primaprima ... 1262102110111112113114122162212 ... ultimoultimo
Visualizzazione dei risultati da 1,111 a 1,120 su 3155
[ROM] [THL-W8/W8s] JellyBean 4.2.2 Rom (samsung style)
  1. #1111
    Hi, guys, sorry I'm not Italian (If you won't mind I will use English). First of all very big thanks for your job, you firmware is brilliant. But I need your help, I have some problem with camera. When installed your firmware I got 'Can't connect to camera' when open camera application.
    I've tried to clean gallery cache
    I've tried to use another camera application
    I've removed flashlight application and did something else and it helped but fro a while
    Now camera again does not work.
    Do you know how can deal with that issue ?
    Thanks.
    which version of W8 ? 4Gb, 8Gb or 16Gb ?
    Nubia Z7MAX
  4. #1113
    Me version is 8 Gb
  5. #1114
    with 8gb version is really strange to have this problem with the camera
    you can try reflash the rom with mod (in aroma) camerafix 4GB. this mod use the THL kernel and camera system lib from THL firmware
    con la versione 8GB è veramente strano avere questo problema con la fotocamera
    puoi provare a riflashare la rom con la mod (in aroma) camerafix 4GB. questa mod usa il kernel THL e le librerie di sistema della fotocamera del firmware THL
    Ultima modifica di PaoloW8; 03-07-13 alle 15:39
    Nubia Z7MAX
  6. #1115
    unfortunately I've tried already use it, before I push coment here, and it does not helped Is it means that I have hardware issue ?
  7. #1116
    you have tried with camerafix16GB also ?
    for check if a hardware issue try with other rom (gravitymod2 for example, [ROM] THL W8 (4GB/8GB/16GB) GravityMod2 - Android 4.2.1 (60 FPS UI) - xda-developers)
    Nubia Z7MAX
  8. #1117
    yep I've tried with both. I just installed official one 4.2.1 (from May if i'm not mistake) And camera started to work for a while, after few reboot and few minutes of usage, it was stop, and I can't get it back
  9. #1118
    so...if the problem also exists with the official firmware i think is a hardware issue
    ask where you bought what you can do
    Nubia Z7MAX
  10. #1119
    Yep thanks ;( I asked now wating response, but in any case response can't be so glad to me sending back will take very long time and too much expensive ;( too bad
  11. #1120
    Hehehe....
    Paolo si e' ....."internazionalizzato"
