| Update Tip: Third Edition solve some problems, Color OS basically perfect!
1, to enhance fluency improved camera settings Caton.
2, the baseband replaced with a new UI 3.30, and do not need to paint the baseband patch.
3, replace audio driver for official driver, problem solving headset wire.
4. Replace WiFi drivers, improve the quality of WiFi connection.
5, by adding the original streamlined out of individual centers, voice assistant.
ROM Description:
1, based on the latest version of OPPO Color OS 2.01 firmware streamline optimization, high with, the standard through the brush!
2. Support the Hall holster, black gestures, NFC! Special thanks Disky greatly to provide technical support!
******NFC switch: Wireless and network - more - pull down --NFC-- can pop open the page!
3, repair compass., Referring to the end of the play much of the bottom package, to express my gratitude to him!
4. Repair the earpiece volume is too small problem, adjust the volume without having to enter engineering mode, putting clear without sonic boom!
5. Add OPPO dedicated camera module (part of the module is invalid)!
6, support Mobile, China Unicom 4G, Card 1, Card 2 support 4G, you can switch directly in the system settings!
7, streamline some not commonly used software and the underlying library!
8, and frame all APP odex files have been consolidated, and have been aligned to optimize!
9, add init.d script support, add busybox instruction set!
10. RF optimization, adjust the minimum brightness to 5, saving electricity, oil release like reading!
11. build.prop adjustment parameters to optimize the touch, the system response speed, Internet speed, improve standby time!
12, add a small amount of promotion, you can uninstall .so files are not added to the lib directory!
Brush Information:
1, Brush Make sure the phone battery is not less than 30%, otherwise easily lead to failures and problems Brush!
2. Brush before your own good contacts, call logs, SMS, backup software and games!
3. Make sure the brush before his master the correct wire brush, brush card tricks, White should not blind Brush!
[Copyright]
1, my ROM support reproduced, welcome to reprint, but reproduced, please indicate the original author!
2, I also welcome the ROM, ROM support you split my own produce better ROM, but please indicate the original author!
3. He does not hold the copyright ROM software, end software packages and which are from the network, learn and communicate using only do!
4, I do not guarantee the suitability of all the good domain ROM S3 with high or standard cell phone, if you download and brush ROM package, then that represents your own risk default agree! Please choose carefully! |
