a lungo quanto? ho provato ma non so per quanto a lungo...
Si scarica la batteria in sta modalità? pensavo di farlo scaricare...
non riesco a riavviarlo ne a spegnerlo...è strana come cosa...come si fa a uscire da qui?
cmq detto in modo più ordinato ho trovato su un forum inglese (senza risp) cosa mi è successo:
Hi
I am having problem with my Volume Down key.
When the phone is ON, the volume down is not working. I can use the volume rocker to get volume UP. But when I press down, though I can feel that DOWN is being pressed, the volume does not turn low. I have to turn the volume low using the slider on the screen.
Also when I restart my phone it goes directly to Fastboot, showing reason for fastboot : Volume down key pressed.
(I would like to add that the volume is not automatically turning down in my phone when it is ON)
I feel its a software issue rather than hardware, however, i am not sure.
Please help.
Also I cannot do factory reset as when the phone restarts it goes to Fastboot. If I choose Recovery in Fastboot and go to the next screen where I have to choose WIPE DATA,/FACTORY RESET, i cannot scroll down to that using volume down, as it does not work.
