Utente della settimana: gianpassa con ben 7 Thanks ricevuti negli ultimi sette giorni
Utente del mese: gianpassa con ben 31 Thanks ricevuti nell'ultimo mese
Pagina 19 di 19 primaprima ... 9171819
Visualizzazione dei risultati da 181 a 181 su 181
[Tool] Resize partition Z7 Max & Mini
  1. #181
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi,
    You no need to do from the begining, The same this happened for me when i did the partition. After restore the Nandroid back up phone gets stuck at boot image.
    Following are the steps which i did without PC and partition size still at 6GB
    -Go to CWM and wipe factory reset + clear cache + dalvik
    -install official 1.59 package with SD card brush at the end it will ask disable recovery flash, Make sure you ignore this.
    - Wait the phone to on, your wifi and bluetooth will not work
    - Come again to recovery flash this file for Wifi and BT by CWM https://mega.co.nz/#!8gVlhAzB!mDrHX2...JDtPQ4721BUO78
    - Reboot the phone, once everything working fine
    - Install TWRP recovery and flash BB72 1.64
