Visualizza i risultati del sondaggio: Quale rom state usando?
Chi ha votato
46. Non puoi votare questo sondaggio
  • Io ho la rom di BB72&Cuoco92 vers. 1-3
    2 4.35%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite recoverry
    16 34.78%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite OTA
    15 32.61%
  • Io ho la rom LEWA multilingua
    4 8.70%
  • Io ho un'altra rom
    9 19.57%
Pagina 159 di 489 primaprima ... 59109149157158159160161169209259 ... ultimoultimo
Visualizzazione dei risultati da 1,581 a 1,590 su 4883
[Alcatel/TCL IdolX+/S960] Guide Root- Recovery- Rom Custom
  1. #1581
    Apr 2014
    Austria - Pinzgau
    Alcatel 6043D
    is there no official place to get the actual boomband apk version?
    Redmi Note 3 Pro, Honor 6
    Ringraziato 803 volte in 570 Posts
    link of boomband app is on first page of this thread or on Alcatel site.
  4. Il seguente Utente ha ringraziato palasix per il post:
    ReDedo (30-04-14)
  5. #1583
    Apr 2014
    Austria - Pinzgau
    Alcatel 6043D
    ahhh OK thx! iam thinking to buy the boom band, is it useful? where to buy it or maybe someone which is not using it, can sell it > if yes, contact me over PM
  6. #1584
    Quote Originariamente inviato da egraneroe Visualizza il messaggio
    Hello guys,
    I was testing the tcl boomband I bought the previous month.
    Well, I had often disconnections from bluetooth and as an outcome every few minutes the boomband was trying to reconnect to the s960.
    After some searching I found the solution:
    I install the new version boombandlife 2.1.2 which is much better and with more options than the 1.1.7 that can be found on the first posts here.
    I upload this version with the pdf-manual in order to be posted in the first pages so as to save time from other s960+boomband owners.
    instruction tips:
    1) uninstall any older boombandlife apk and install this one
    2) connect the boomband with the phone
    3) from the phone app go to settings==>my devices and do the 2.0.2 firmware update that will update your boomband in a minute.
    4) enjoy!
    Download: https://mega.co.nz/#!HB5mSIKZ!VWtv3u...zLYh0hI3-ioz8E
    Really thanks for your contribution! Some boomband users noticed the same issues and now it is good to know that problems are related to boomband sw management and not to the phone BT....;O)
    Inviato dal mio SM-P605 usando Androidiani App
  7. Il seguente Utente ha ringraziato BB72 per il post:
    ReDedo (30-04-14)
  8. #1585
    iocex7 , tcl idol, mi note
    cuoco ora è ok forse stanotte il server nn andava , ho fatto anche ricalibrato la batteria ma noto che scende più veloce come mai
  9. #1586
    new boomaband link put on first page
  10. Il seguente Utente ha ringraziato palasix per il post:
    ReDedo (30-04-14)
  11. #1587
    Quote Originariamente inviato da andreamor Visualizza il messaggio
    Installate CPU SPY, azzerate i contatori delle cpu e controllate se in standby il celll va in deepsleep. Se non ci va allora ci sono dei wakelock! Inoltre se siete in luoghi dove il 3G prende male e il sistema fa continuamente lo switch tra 2G e 3G avrete un consumo nettamente più alto....quindi in questi casi vi consiglio di forzare in 2G only....
  12. Il seguente Utente ha ringraziato BB72 per il post:
    ReDedo (30-04-14)
  13. #1588
    Apr 2014
    ciao a tutti.(scusatemi per il mio italiano,sono russo) è arrivato s960 sensa la radio fm installata.forse e una vers.di tel.particolare?la vers 14.01.10.ho scaricato la vers 14.04.01 ma non riesco installarla.qualquno mi puo aiutare
  14. #1589
    e si effettivamente nn và mai totalmente in deep sleep rimane sempre la cpu 0 -1 attiva
    Ultima modifica di andreamor; 30-04-14 alle 15:41
  15. #1590
    Il motivo è quello allora e devi capire quale processo/applicazione ti crea il wakelock....ti preannincio che non è semplicissimo ma ti può essere d'aiuto BetterBatterystats oppure Wakelock Detector....puoi documentarti in Interenet c'è di tutto....
