Pagina 52 di 79 primaprima ... 242505152535462 ... ultimoultimo
Visualizzazione dei risultati da 511 a 520 su 786
Ulefone U69/U7, Carpad T69, Tronsmart PS7, Yuandao M87, OrientPhone Mega Pro 7.0
  1. #511
    cdr
    cdr non è in linea
    nuova rom 4.4.3
    Quote Originariamente inviato da albanomax Visualizza il messaggio
    non trovo il link della rom
    Eccolo:
    https://mega.co.nz/#!Et8xlQAA!oyA1hd...FkTSOU7nS8T8fQ
    In realtà è per il Luftco A One X, che si è dimostrato aver ROM compatibili con il nostro. Pare sia un porting della ROM Mlais m81 update 0902
    Queste le info riguardo la ROM:
    FW from Biscuit Team 4.4.3
    This ROM features: the external card swap, signal enhancement, GPS optimization, minimum brightness adjustment
    1, the card is based on MLS official Brush Pack Second Edition ( 902) firmware streamline optimization, migration from!
    2, streamline a lot less common software and invalid underlying driver! Added some commonly used software!
    3, the 3rd generation Sony imaging adding patches to optimize the display!
    4, adjust the init.d script, optimize touch, significantly increasing system fluency!
    5, by adding specially optimized for 6592 MtkTweak 14, optimize memory footprint, offers a variety of performance mode selection for oil! Performance option from the top down, turn reduces performance, power in turn strengthened the general election energy balance can be! Memory options, choose 2G recommended values ​​can be!
    6, adding IPhone style floating window, you can adjust the screen to minimum brightness, rich function keys can be customized. . .
    7, this ROM has root! Using superSU authorized!
    8, joined Sony XLoud and alcohol tone sound, loud and headphone sound quality dramatically , putting clear without breaking sound, headphone deep sound field broad, clear voice !
    9, update titanium backup for the relatively new version, updated to version 3.2 RE Manager, add search star assistant! Launcher updated to APEX PRO 2.6 crack version!
    10, adjust the minimum brightness is 2, the normal use of the brightness of 50, brightness adjustment increase of 10! Per level
    11, joined the super power patch, effective control of a good power to ask!
    12, GPS enhanced optimization, first open WiFi and GPS, Star Search 15, connecting 8-9 stars, time 1-2 minutes and the second single off open WiFi GPS, Star Search 12, even eight!
    Install it with CWM (TWRP) recovery.
    LInks - A_oneX_4.43_0908 by ??.zip_??????|??? ??-????? https://mega.co.nz/#!Et8xlQAA!oyA1hd...FkTSOU7nS8T8fQ
    Source is - Tronsmart Blade PS7 / Ulefone U7 - Îáñóæäåíèå - 4PDA There are manuals for flashing and other usefull information (on Russian, thanks GoogleTranslate - all is clear).
    Io non ho provato, ho poco tempo oltre al fatto di avere sul cell vari generatori di token che utilizzo...
    Se qualcuno riesce lo faccia sapere, grazie.
    ciao,
    cdr
  2. Il seguente Utente ha ringraziato cdr per il post:
    albanomax (09-10-14)
    ho messo questa rom 20140902_e2719v92_gq3015_m81.rar ed effettivamente mi dice 4.4.3
    è la prima rom personalizzata che vedo,il volume resta basso,mi interessava questa cosa ma penso che l'esigenza non sia solo mia
    altre migliorie per ora non nè noto l'ho appena messa....
    grazie cdr per le preziose info ;D
  5. #513
    cdr
    cdr non è in linea
    Dunque non hai messa quella del Luftco (A_oneX_4.43_0908.zip)... funziona tutto bene (GPS, sensori, fotocamera, ecc) ?
    La luminosità si riesce ad abbassare piu' di prima ?
    Dicci tutto sulla ROM 4.4.3 sei il primo ad averla messa su questo forum
    Grazie,
    cdr
  6. #514
    no ho messo questa ROM Mlais M81 | [Official]-[Updated] add the 08/08/2014 on Needrom
    in tutti i modi non è possibile aspettare che avvenga il miracolo,capisco che ognuno ha le proprie esigenze ma miglioramente con le nuove rom pare siano sempre o quasi sempre invisibili boh
    avevo prima uno star s7589 che aveva il led che non faceva luce,molti ricordo cambiarono anche il led,poi per sbaglio o per caso provai una rom e il led faceva una luce impressionante
    non so' che dire sembra come se questi terminali venissero impostati al 60% delle loro potenzialità,l'audio messo al massimo non è alto e neanche và in distorsione,percui penso proprio che sia troncata qualche impostazione....
  7. #515
    sabato la provo la luftco cmq ci manca solo che non la provo credi sia meglio della mlais ??
    la luftco pesa la metà della mlais come mai?? 366mb contro i 760mb della mlais....
    Ultima modifica di albanomax; 09-10-14 alle 01:15
  8. #516
    cdr
    cdr non è in linea
    La Mlais non mi pare sia custom ed occupa piu' o meno come le altre ROM.
    La Luftco invece è moddada abbastanza pesantemente con rimozione di parecchia roba: per quello risulta interessante
    Quando la proverai ti farò qualche domandina, grazie
    ciao,
    cdr
  9. #517
    Senior Droid L'avatar di dariettoit
    Apr 2014
    Meolo
    ecoo e04 plus
    Ringraziato 99 volte in 90 Posts
    Quote Originariamente inviato da cdr Visualizza il messaggio
    Eccolo:
    ciao,
    cdr
    Oggi quasi sicuramente la provo ma vi vuole la cwm? Io non la trovo
    Smanettare is the way^^
  10. #518
    difatti la stavo provando giusto ora ma serve il root altrimenti in formato zip come la installo,non ho nenche provato ma al 100% l'installazione abortisce....
  11. #519
    Apr 2014
    Meolo
    ecoo e04 plus
    Mi mandate la cwm per favore???
  12. #520
    Apr 2014
    Meolo
    ecoo e04 plus
    Per piacereeeeeeeeeee
