quindi con rom nuova non hai la radio?
cmq invio anche per i meno esperti i passaggi per l'apk in questione:
1. Install the program to the device.
2. Execute the program
3. Select “Set”, and then screen should show “write done”.
4. Reset the device.
PS. If the screen shows other message instead of “write done” after selecting “Set”,
