Confermo tutto ok e bastato un riavvio (sebbene abbia fatto i 3 wipe).
Cmq il 3G funge anche con Wind.
Ora ho installato 2 cosette sto facendo un backup e poi ci lavoro per ampliare il market.
FOUREIGHT::::::::::::::::::::mandami per favore le quattro stringhe ORIGINALI..stupidamente non le ho salvate.Grazie
Ok, non avevo visto questo tuo...
ecco il mio per intero:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=GINGERBREAD
ro.build.display.id=GINGERBREAD Simongabry RootMarketNew rev02
ro.build.version.incremental=eng.bingo.20110906.17 2522
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.3
ro.build.date=Tue Sep 6 17:31:53 CST 2011
ro.build.date.utc=1315301513
ro.build.type=user
ro.build.user=bingo
ro.build.host=foxda-desktop
ro.build.tags=release-keys
ro.product.model=AN7CG2
ro.product.brand=ARCHOS
ro.product.name=msm7627_fw8918
ro.product.device=msm7627_fw8918
ro.product.board=7x27
ro.product.cpu.abi=armeabi
ro.product.manufacturer=FOXDA
ro.product.locale.language=hdpi
ro.product.locale.region=
ro.wifi.channels=
ro.board.platform=msm7k
# ro.build.product is obsolete; use ro.product.device
ro.build.product=msm7627_fw8918
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=msm7627_fw8918-user 2.3.3 GINGERBREAD eng.bingo.20110906.172522 release-keys
ro.build.fingerprint=ARCHOS/msm7627_fw8918/msm7627_fw8918:2.3.3/GINGERBREAD/eng.bingo.20110906.172522:user/release-keys
# end build properties
# system.prop for ffa
rild.libpath=/system/lib/libril-qc-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
debug.sf.hw=1
debug.composition.type=mdp
dalvik.vm.heapsize=24m
# system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
# system prop for opengles version
ro.opengles.version=131072
# system props for the data modules
ro.use_data_netmgrd=false
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
#FOXDA_START
persist.service.adb.enable=0
ro.sf.display_images=3
ro.sf.local_path=/content/
ro.config.hasphone=false
#FOXDA_END
#jewen bt power class
qcom.bt.dev_power_class=2
#rotation to 480*800 display
ro.sf.hwrotation=270
# ADDITIONAL_BUILD_PROPERTIES
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
per SIMONGABRY -----------------------Grazie fatto,poi provo il gps.Un'altra cosa ..quando dice "applicazione non installata" secondo te esiste una possibilità per installarla ?? forse il nostro arnova non è fra quelli abilitati a ricevere l' app in questione???
Ultima modifica di giver; 04-03-12 alle 13:10
@simongabry
Bella rom stabile e funzionale 3G, wifi gps peccato il market che trova poche cose
Su quelle stringhe ho provato con i dati della rom di setialpha ma non sono riuscito a migliorare.
Piu tardi provo con i dati postati da daniel anzi se qualcuno nel frattempo...
ciaooo
Volevo solo segnalare che il passagio tasto + - + dalla recoveri si fa e funziona, volevo altresi ricordare che per passare in recovery mode non è necessario per forza passare da cmd adb recovery ecc. ... ma basta passare da : drawer (home app) \ Impostazioni \ Info sul dispositivo \ Aggiornamenti sistema , il tablet si spegne e si riaccende in recovery sia CMW o la originale. Ciaoz![]()
Provato sia con il build.prop di setialpha che con le modifiche di Daniel ma nessuna variazione al market, c'è qualche applicazione specifica che sicuramente è scaricabile con la rom di setialpha e non con la mia?
Io ho provato viber e indoona che erano le uniche due citate ma non so se con la rom di setialpha sono scaricabili dal market oppure no.
La Rom funziona molto bene..il tablet è molto stabile e veloce..nessun riavvio o problema di altro genere!
Segnalo solo la diminuzione della durata della batteria, con l'originale riuscivo a vedere due film da un ora e trenta..mentre ora con il primo film si arriva già al 15% della batteria..
Noto anch'io la poca ricchezza del market ufficiale.. CIAO!!!
Arnova 7cG2
Xperia T
