Pagina 31 di 68 primaprima ... 21293031323341 ... ultimoultimo
Visualizzazione dei risultati da 301 a 310 su 673
[GUIDA] Installazione Room su Arnova 10 G2
  1. #301
    Ho cantato vittoria troppo presto... ora riesco ad accedere ma ho poche App... ho provato la solita procedura di cancellazione dei dati del market e del google net framework, e il riavvio del tablet più volte, ma nulla...
    Ringraziato 137 volte in 114 Posts
    Io non so più come dirvelo:
    Se sguite il punto A è per chi non riesce a stabilire la connessione, se seguite il punto B è per chi vede poche app. La procedura è quella scritta da Finless per la rom 1.4... fate voi!
    4) Market issues. Market issue "may" still exist. This is common on tablets that are not really supported by Google as a registered device. Most users have no issues but sometimes there can be, The 2 issues that seem to arise when your FIRST TIME try to use the Market are:
    A) Cannot logon; "Cannot establish a reliable data connection"
    I have tried to recreate this and troubleshoot this. My belief if in fact this happens sometimes when Google servers are doing something or something is going on with them. WHen I had this happen once I simply waited a while and it worked later. So I cannot help too much here. My only suggestion to try is this
    a) Install a root file manager like root explorer or ES file manager (enable root access for them)
    b) Go in with the file manager and delete /data/misc/imei/imei or data.dat which ever one exists
    B) Limited apps listed; I have reproduced this and know how to recreate it and fix it! This has to do (I beleive) that after a factory reset or a flash the tablet creates a ID based on some other IDs and a random key generator. Sometimes this ID Google does not like. So we have to clear that and reboot.
    YOU DO NOT EVER NEED TO REFLASH OR DO A FACOTRY RESET TO FIX THIS!!!!
    DO the following
    a) Again using a file manager that has root access go in and delete the follow folders from the /data/data directory.
    com.android.vending (not com.applib.vending!)
    com.android.vending.updater
    com.google.android.gm
    com.google.android.gsf
    b) Reboot and do nothing else but run the market. YOu should get a prompt asking you to accept the Google terms of service. If you did not you did something wrong. Do it again. If you do get the prompt, accept and now the Market should work fully with TONS of apps showing up.
  4. #303
    Quote Originariamente inviato da crackmania
    DO the following
    Eh lo so! Ma sei non riesco ad abilitare il file manager, non vado da nessuna parte...
  5. #304
    Scarica ES gestore file, apri l'app, premi il tasto menù (quello con i 4 trattini in alto a destra), poi impostazioni, scendi fino in fondo e premi "sfoglia come root" e "monta file system"... ed il gioco è fatto, hai il file manager che può scrive/leggere!!!
  6. #305
    Quote Originariamente inviato da crackmania Visualizza il messaggio
    ma se il problema è che il market trova poche applicazioni,mi spieghi come faccio a trovarla? =D ho provato a cercarla ma nulla... l'unica che trovo gel genere file manager è OI File Manager...
  7. #306
    Quote Originariamente inviato da JeanFi
    Dopo l'ennesima volta che cancello la cache da framework e market ora me le visualizza tutte... mah... scusate per i disagi... e grazie davvero per il supporto =)
  8. #307
    Va bèh, meglio così! L'importante è che hai risolto!
    Comunque se anche altri hanno il problema delle poche app nel Market o che il Market non funziona e non possono scaricare un file manager, vi lascio il sito dal quale prenderlo: Download
    Il primo è quello che serve a noi!
  9. #308
    Grazie mille ancora =)
  10. #309
    Aggiornamenti??
  11. #310
    ciao a tutti..il file riguardante i driver della romdi jackgar non me lo fa scaricare non mi trova il sito...succede anche a qualcun altro?
LinkBacks (?)
  1. 11-07-12, 15:18
  2. 09-07-12, 15:57
  3. 09-07-12, 15:36
  4. 09-07-12, 15:29
  5. 09-07-12, 15:25
  6. 16-06-12, 23:53
  7. 19-05-12, 21:43
  8. 31-03-12, 18:32
  9. 30-03-12, 14:31
  10. 30-03-12, 11:07
  11. 19-03-12, 22:29
  12. 18-03-12, 20:45
  13. 18-03-12, 03:13
  14. 05-03-12, 17:13
  15. 26-02-12, 10:36
  16. 24-02-12, 14:10
  17. 19-02-12, 16:32
  18. 10-02-12, 03:03
  19. 09-02-12, 14:41
  20. 31-01-12, 23:16
  21. 30-01-12, 22:11
  22. 23-01-12, 18:38
  23. 23-01-12, 17:55
  24. 23-01-12, 14:19
  25. 23-01-12, 13:31
  26. 23-01-12, 13:29
  27. 23-01-12, 12:46
  28. 23-01-12, 12:34
  29. 12-01-12, 14:53
  30. 03-01-12, 00:09
  31. 29-12-11, 13:28
  32. 28-12-11, 14:25
  33. 27-12-11, 12:55
  34. 27-12-11, 11:24
  35. 27-12-11, 02:58
  36. 27-12-11, 02:27
  37. 26-12-11, 23:56
  38. 26-12-11, 15:16
  39. 21-12-11, 10:59
  40. 16-12-11, 16:38
