• REGOLAMENTO • CONSIGLI SULL'UTILIZZO DEL FORUM • F.A.Q. DEL FORUM • MANUALE BBCODES •
Smartphone:
Uscito il nuovo update per ZE500CL!
Changelog: [150521] ZE500CL_WW_V12.16.5.61-Release Note
【Version】
V12.16.5.61
【Model Name】
ZenFone2 (ZE500CL)
【Release Date】
2015/06/04
【Release Note】
Fix green line issue shown on the bottom of the preview screen when no moving object was detected in Smart Remove mode
Fix charging capacity issue in charging mode
Fix the issue that after installing Automatic Call Recorder, the voice call would be muted
Fixing intermittent two-volume-level change with one key press
Fix reboot issue which occurs when installing Google IME to external storage directly from Google Play store.
Fix the following Italian translation issues:
- Theme application is not localized
- Under Preferences options several prompts are not localized
- Icon Label Color options are not translated in Italian
- Icon Pack option is not localized
- Prompt error into ASUS Backup application is not properly localized"
New Feature
Other 3rd Party Apps: Google Drive – Free 100 GB space of Google Drive for 2 years.
Enjoy 100 GB of FREE storage!Redeem this offer in the Google Drive app by March 8, 2016.
Add Yahoo Shopping (Taiwan only)
Add Yahoo Store (Taiwan only)
Add EZTABLE (Taiwan, Thailand and Hong Kong only)
Update several Apps including ZenUI
crazyfunny (04-06-15),MatteXperiaU (04-06-15)
finalmente anche lo ZE500CL si aggiorna. aggiunto al primo post
lefantome (04-06-15)
Appena aggiornato! Nessuna novità evidente,la fotocamera continua a fare pena! I viedo vanno a scatti anche con buona illuminazione ora scattano pure in piena luce,bel miglioramento!
Ma a voi i video sono fluidi in tutte le condizioni di luce,possibile che solo io lamento questo problema?
Ultima modifica di massidell; 04-06-15 alle 16:48
tutto ok quindi?
nuovo firmware per il 551ML via OTA
ZE551ML_ WW_ V2.18.40.12
changelog [150529] ZE551ML_WW_V2.18.40.12-Release Note
ciao a tutti
C'è modo per disabilitare la ricerca automatica degli aggiornamenti via ota?
Comunque stanno realmente rilasciando un aggiornamento ogni 7/10 giorni. Se continuasse così, sarebbe davvero una gran cosa. Complimenti ad Asus per quanto fatto fino ad ora.![]()
Ultima modifica di Elektrosphere; 04-06-15 alle 18:15
****I Thanks sono sempre graditi!!****
Ho semplicemente aggiornato il telefono tramite l'aggiornamento automatico. Al completamento il telefono è bloccato in bootloop, senza alcun motivo...
Ho il root e la CWM. Ho provato anche a fare il wipe cache... Soluzioni?
Io ho aggiornato, telefono stock e per ora perfetto
Inviato dal mio ASUS_Z00AD usando Androidiani App
