Pagina 144 di 250 primaprima ... 4494134142143144145146154194244 ... ultimoultimo
Visualizzazione dei risultati da 1,431 a 1,440 su 2497
[Honor 6]AGGIORNAMENTI UFFICIALI/INFO/PROBLEMI INSTALLAZIONE
  1. #1431
    Baby Droid L'avatar di CrazyJuly
    Quote Originariamente inviato da grxmix Visualizza il messaggio
    Questo sembra sia il change log
    [System] • Support on ARM v8, x86-64, and MIPS-64 architectures and fully 64-bitcompatible.<br />
    Enhance the VoLTE feature.<br />
    Improved app startup performance. Android now runs exclusively on the new<br />
    ART runtime.<br />
    Improve Wi-Fi experience.<br />
    <br />
    [Home screen] • Added the ability to sort the shortcut switches in the notification panel, enable<br />
    you to customize your shortcut switches.<br />
    Add mini screen view. You can swipe left or right on the Home key to enable this view, or swipe in the opposite direction or touch any blank area to exit this view.<br />
    <br />
    Optimize the background and font color of the notification panel.<br />
    Optimize the display effect of the shortcut switches in the notification panel.<br />
    Optimize notification management.<br />
    [Camera] • Add time-lapse mode so you can create an accelerated video of a slow-changing scene.<br />
    Add light painting and super night modes to let you adjust the exposure time and<br />
    take pictures with light trails or silky water.<br />
    [Gallery] • Add the mosaic and graffiti features to let you edit your pictures in more<br />
    innovative way.<br />
    [Apps] • Remove the Bitcasa app as it is not compatible with Android 5.1.<br />
    Add automatic unlock feature when your phone is connected to a Bluetooth<br />
    wearable devices. You can unlock the phone from your wearable devices without<br />
    the password.<br />
    Add a lock screen notification feature to let you check new notifications without<br />
    unlocking your phone.
    Come vedi nella parte della Camera parla di time-lapse e slow-changing scene
    Grazie mille, gentilissimo
    Quote Originariamente inviato da akiramax Visualizza il messaggio
    Non è lo slow motion ma il time lapse... Quello a cui si riferisce è creare un video veloce di foto fatte in tempi lunghi
    Azz, grazie
  4. Il seguente Utente ha ringraziato CrazyJuly per il post:
    krix77 (13-07-15)
  5. #1433
    Vabbè in ogni caso nel change log si parla di entrambi
  6. #1434
    Sep 2009
    Comunque a quanto ne so nemmeno il p8 ha lo slow motion e credo nemmeno l'honor 7
  7. #1435
    Peccato cavolo, é un opzione che ha fatto il boom con l's4 insomma.. Quindi parliamo di qualche annetto fa..
  8. #1436
    Quote Originariamente inviato da CrazyJuly Visualizza il messaggio
    Intanto che aspetti che esca l'upgrade ufficiale per vedere se verrà implementato puoi provare a scaricare l'app lapse it pro
    Ultima modifica di grxmix; 12-07-15 alle 18:58
  9. #1437
    Androidiano L'avatar di pazzokli
    Quote Originariamente inviato da sentimento21 Visualizza il messaggio
    Preferivi avere la 5.0 qualche mese fa?
    Diciamo che speravo arrivasse a giugno anche per il mio L02 e magari potessi sfruttare la 3 che ora ho abbandonato per il roaming.
  10. #1438
    HTC Desire HD Nexus 4
    Quindi é ancora presente il problema del roaming con la 3?
  11. #1439
    OnePlus3 -Xiaomi Mi Mix 2S
    Ringraziato 162 volte in 150 Posts
    Quote Originariamente inviato da drunkct Visualizza il messaggio
    Con l'ultima stabile b316 il roamning funziona, con l'ultima developer 5.7.1 invece il problema c'è ancora.
  12. #1440
    Quote Originariamente inviato da visce1 Visualizza il messaggio
    Ah ecco, perché sono ripassato a 3 da qualche giorno e non avevo riscontrato il problema avendo la b316 sul mio L02.
    Grazie.
