Configurare Azilink
Salve a tutti,
seguendo la guida presente nel forum ho installato Azilink per effettuare il tethering USB con il mio Magic, ma non mi funziona.
Il mio file di configurazione azilink.avpn contiene:
dev tun
remote 127.0.0.1 41927 tcp-client
ifconfig 192.168.56.2 192.168.56.1
route 0.0.0.0 128.0.0.0
route 128.0.0.0 128.0.0.0
#socket-flags TCP_NODELAY
#keepalive 10 30
ping 10
dhcp-option DNS 192.168.56.1
route-method exe
route-delay 2
ed il risultato dello status di OpenVPN è:
Mon Sep 14 22:55:17 2009 us=709000 Current Parameter Settings:
Mon Sep 14 22:55:17 2009 us=709000 config = 'azilink.ovpn'
Mon Sep 14 22:55:17 2009 us=709000 mode = 0
Mon Sep 14 22:55:17 2009 us=709000 show_ciphers = DISABLED
Mon Sep 14 22:55:17 2009 us=709000 show_digests = DISABLED
Mon Sep 14 22:55:17 2009 us=709000 show_engines = DISABLED
Mon Sep 14 22:55:17 2009 us=709000 genkey = DISABLED
Mon Sep 14 22:55:17 2009 us=709000 key_pass_file = '[UNDEF]'
Mon Sep 14 22:55:17 2009 us=709000 show_tls_ciphers = DISABLED
Mon Sep 14 22:55:17 2009 us=709000 Connection profiles [default]:
Mon Sep 14 22:55:17 2009 us=709000 NOTE: --mute triggered...
Mon Sep 14 22:55:17 2009 us=709000 262 variation(s) on previous 10 message(s) suppressed by --mute
Mon Sep 14 22:55:17 2009 us=709000 OpenVPN 2.1_rc19 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Jul 16 2009
Mon Sep 14 22:55:17 2009 us=709000 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Mon Sep 14 22:55:17 2009 us=709000 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Sep 14 22:55:17 2009 us=709000 ******* WARNING *******: all encryption and authentication features disabled -- all data will be tunnelled as cleartext
Mon Sep 14 22:55:17 2009 us=725000 ROUTE: default_gateway=UNDEF
Mon Sep 14 22:55:17 2009 us=740000 TAP-WIN32 device [Connessione alla rete locale (LAN) 2] opened: \\.\Global\{6E92E202-8337-457C-8200-FC105EDAA27A}.tap
Mon Sep 14 22:55:17 2009 us=740000 TAP-Win32 Driver Version 9.6
Mon Sep 14 22:55:17 2009 us=740000 TAP-Win32 MTU=1500
Mon Sep 14 22:55:17 2009 us=740000 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.56.2/255.255.255.252 on interface {6E92E202-8337-457C-8200-FC105EDAA27A} [DHCP-serv: 192.168.56.1, lease-time: 31536000]
Mon Sep 14 22:55:17 2009 us=740000 DHCP option string: 0604c0a8 3801
Mon Sep 14 22:55:17 2009 us=740000 Successful ARP Flush on interface [18] {6E92E202-8337-457C-8200-FC105EDAA27A}
Mon Sep 14 22:55:17 2009 us=756000 Data Channel MTU parms [ L:1502 D:1450 EF:2 EB:4 ET:0 EL:0 AF:14/2 ]
Mon Sep 14 22:55:17 2009 us=756000 Local Options String: 'V4,dev-type tun,link-mtu 1502,tun-mtu 1500,proto TCPv4_CLIENT,ifconfig 192.168.56.1 192.168.56.2'
Mon Sep 14 22:55:17 2009 us=756000 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1502,tun-mtu 1500,proto TCPv4_SERVER,ifconfig 192.168.56.2 192.168.56.1'
Mon Sep 14 22:55:17 2009 us=756000 Local Options hash (VER=V4): '14d5141a'
Mon Sep 14 22:55:17 2009 us=756000 Expected Remote Options hash (VER=V4): '84280bec'
Mon Sep 14 22:55:17 2009 us=756000 Attempting to establish TCP connection with 127.0.0.1:41927
Mon Sep 14 22:55:17 2009 us=756000 TCP connection established with 127.0.0.1:41927
Mon Sep 14 22:55:17 2009 us=756000 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Sep 14 22:55:17 2009 us=756000 TCPv4_CLIENT link local: [undef]
Mon Sep 14 22:55:17 2009 us=756000 TCPv4_CLIENT link remote: 127.0.0.1:41927
Mon Sep 14 22:55:27 2009 us=7000 Peer Connection Initiated with 127.0.0.1:41927
Mon Sep 14 22:55:33 2009 us=403000 TEST ROUTES: 1/1 succeeded len=1 ret=1 a=0 u/d=up
Mon Sep 14 22:55:33 2009 us=403000 C:\WINDOWS\system32\route.exe ADD 192.168.56.0 MASK 255.255.255.252 192.168.56.1
Mon Sep 14 22:55:33 2009 us=481000 Initialization Sequence Completed
Qualcuno mi può aiutare?
Grazie mille.
Che errore ti dà? Non riesci a navigare su internet?
Hai provato a fare un ping?
ping Google
ping 209.85.129.103
1 allegato(i)
Riproviamo
La cosa strana è che non mi da errori, il logo con i due computerini di OpenVPN diventa verde e il programma nel Magic mi scrive "Connected to host".
Ho provato a fare il ping 192.168.56.1 e non da alcun errore.
Ho provato a modificare il file di configurazione lasciando praticamente invariati i parametri impostati come segue:
dev tun
#keepalive 10 30
ping 10
route-method exe
route-delay 2
ed lo status una volta effettuata la connessione è:
Thu Sep 17 12:10:14 2009 OpenVPN 2.1_rc19 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Jul 16 2009
Thu Sep 17 12:10:14 2009 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Thu Sep 17 12:10:14 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Thu Sep 17 12:10:14 2009 ******* WARNING *******: all encryption and authentication features disabled -- all data will be tunnelled as cleartext
Thu Sep 17 12:10:14 2009 TAP-WIN32 device [Connessione alla rete locale (LAN) 2] opened: \\.\Global\{6E92E202-8337-457C-8200-FC105EDAA27A}.tap
Thu Sep 17 12:10:14 2009 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.56.2/255.255.255.252 on interface {6E92E202-8337-457C-8200-FC105EDAA27A} [DHCP-serv: 192.168.56.1, lease-time: 31536000]
Thu Sep 17 12:10:14 2009 Successful ARP Flush on interface [18] {6E92E202-8337-457C-8200-FC105EDAA27A}
Thu Sep 17 12:10:14 2009 Attempting to establish TCP connection with 127.0.0.1:41927
Thu Sep 17 12:10:14 2009 TCP connection established with 127.0.0.1:41927
Thu Sep 17 12:10:14 2009 TCPv4_CLIENT link local: [undef]
Thu Sep 17 12:10:14 2009 TCPv4_CLIENT link remote: 127.0.0.1:41927
Thu Sep 17 12:10:24 2009 Peer Connection Initiated with 127.0.0.1:41927
Thu Sep 17 12:10:27 2009 Initialization Sequence Completed
Fatto questo il risultato che mi ritrovo in "Connessioni di rete" lo puoi vedere nell'immagine allegata.
Qualche idea?
Grazie mille!
Problema risolto!!
Problema risolto!!
Non mi ero accorto che alla macchina virtuale installata sul mio pc avevo assegnato esattamente lo stesso indirizzo IP.
Cambiato indirizzo è partito subito come una bomba!!!
BYE!! :D:D:D:D:D
a me invece da questo errore...
codice:
Mon Sep 28 12:40:29 2009 OpenVPN 2.1_beta7 Win32-MinGW [SSL] [LZO2] built on Nov
12 2005
Mon Sep 28 12:40:29 2009 IMPORTANT: OpenVPN's default port number is now 1194, b
ased on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earl
ier used 5000 as the default port.
Mon Sep 28 12:40:29 2009 WARNING: --ping should normally be used with --ping-res
tart or --ping-exit
Mon Sep 28 12:40:29 2009 ******* WARNING *******: all encryption and authenticat
Mon Sep 28 12:40:29 2009 TAP-WIN32 device [Connessione alla rete locale (LAN) 3]
opened: \\.\Global\{BE0CC87F-27CF-4B54-B9CB-450F220D3C98}.tap
Mon Sep 28 12:40:29 2009 Notified TAP-Win32 driver to set a DHCP IP/netmask of 1
92.168.56.2/255.255.255.252 on interface {BE0CC87F-27CF-4B54-B9CB-450F220D3C98}
Mon Sep 28 12:40:29 2009 Successful ARP Flush on interface [4] {BE0CC87F-27CF-4B
Mon Sep 28 12:40:29 2009 UDPv4 link local (bound): [undef]:1194
Mon Sep 28 12:40:29 2009 UDPv4 link remote: 127.0.0.1:41927
Mon Sep 28 12:40:29 2009 read UDPv4: Connection reset by peer (WSAECONNRESET) (c
ode=10054)
Mon Sep 28 12:40:39 2009 read UDPv4: Connection reset by peer (WSAECONNRESET) (c
ode=10054)
ode=10054)
Mon Sep 28 12:40:49 2009 read UDPv4: Connection reset by peer (WSAECONNRESET) (c
ode=10054)
ode=10054)
Il file di configurazione è lo stesso riportato nel post sopra (l'ho copiato da là)
la vesione di openvpn è openvpn-2.1_beta7-gui-1.0.3-install.
Suggerimenti??
grazie!!!
Ecco il mio conf
di seguito riporto il file di configurazione sicuramente funzionante
dev tun
#keepalive 10 30
ping 10
route-method exe
route-delay 2
Le ultime due righe servono solamente per Vista. Verifica che il range di indirizzi impostati per la VPN non siano utilizzati da altri programmi.
