Pagina 10 di 31 primaprima ... 8910111220 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #91
    Aug 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    you are right, I have wrote "last version" but I meant "latest version" (as meaning the newer version)...now I have correct and I will continue to update it
    for the other problem, in YIOS the thermal engine it is not working properly and consequently the frequency of the CPU and GPU remains low (which is why AnTuTu score is 30k-35k)
    however in this rom the thermal engine works properly, the frequencies are raised and obviously also increases the heat (like the firmware stock)
    I do not play on the phone but I tried with angry bird 2 for half an hour and the temperature seemed to me normal
    alright,I get it.looking forward to the next version.
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    umh...try to flash this zip (without wipe) and see if change something
    cm12.1_delqcril.zip
    Same problem here. Testing patch.
  4. #93
    link release V7 and changelog in first page
  5. #94
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Port Nubia camera v.5.2 from new stock (Android 5.1.1) here
  6. I seguenti 2 Utenti hanno ringraziato brooklyn2006 per il post:
    PaoloW8 (20-08-15),securecrt (21-08-15)
  7. #95
    Jan 2015
    Nubia Z7 Max
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Can anyone rehost this? I can't get to the file
  8. #96
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    on mega: nubiaCamera_5.2.apk
  9. #97
    Jan 2015
    Nubia Z7 Max
    Thank you very much Paolo, installing it now
  10. #98
    link version v8 and changelog in first page
  11. #99
    Feb 2014
    Hi Paolo, in V8 camera cyano not existing, and Nubia cameras not work both versions.
  12. Il seguente Utente ha ringraziato migel121 per il post:
    PaoloW8 (21-08-15)
  13. #100
    Quote Originariamente inviato da migel121 Visualizza il messaggio
    ok, I check
  14. Il seguente Utente ha ringraziato PaoloW8 per il post:
    migel121 (21-08-15)
