Pagina 8 di 31 primaprima ... 67891018 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #71
    Quote Originariamente inviato da Kokireg Visualizza il messaggio
    Allegato 148512
    this is what appears ca me and I have more data.
    Occasionally the data not long but almost never work in 4G.
    before it worked very well in V2
    umh...try to flash this zip (without wipe) and see if change something
    cm12.1_delqcril.zip
    Jan 2015
    hello
    first thks.
    I put your fix but i have no change.
    I have no data and sometimes i have data but no LTE.
    I will have try a full install.
  4. #73
    hello
    first thks.
    you have tried to change the preferred network type ?
    yes, you can try with a full wipe but before this you can also try with V4 release
  5. #74
    Jan 2015
    yes of course i have tried with different network type but no change.
    OK i have tried the V4. Can I put the V4 on V5 for test or i must full install V4.
    thks
  6. #75
    Try to flash over the v5, if still not work reflash with a full wipe
    Nubia Z7MAX
  7. #76
    Jan 2015
    I installed the v5 with a full wipe.
    The problem are solve I think.
    And I have a problem with a watch too (garmin Fenix 3) who function now.
    So it's good for the moment.
    Thks
    Sorry for my language but I m french
  8. #77
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    cm12.1_delqcril.zip
    Yesterday I encountered the similar issue, My 4G can't work at all , the data only stay in the 2G. But after reboot the phone it works back to normal.
    I can't make sure is it the CM problem or the Radio part firmware issues.
  9. #78
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    in V5 the network preferred list is again broken (like some versions ago) -.-
    I'm working to fix
    edit:
    V5 fix network preferred list
    cm12.1_V5fix_preferrednetwork.zip
    Ultima modifica di PaoloW8; 11-08-15 alle 15:03 - Motivo: added fix
  10. Il seguente Utente ha ringraziato PaoloW8 per il post:
    securecrt (12-08-15)
  11. #79
    link and changelog release V6 in first page
  12. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    luiseteyo (13-08-15),no1chan (13-08-15),securecrt (13-08-15)
  13. #80
    Jul 2015
    Thank you very much for your great work! Updating... : *
