Pagina 11 di 31 primaprima ... 91011121321 ... ultimoultimo
Visualizzazione dei risultati da 101 a 110 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #101
    Quote Originariamente inviato da migel121 Visualizza il messaggio
    Hi Paolo, in V8 camera cyano not existing, and Nubia cameras not work both versions.
    ok, try to flash this zip (without wipe)
    cm12.1_V8_camerafix.zip
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    migel121 (21-08-15)
    Feb 2014
    After the flashing the zip Camera Cyano not exist, Nubia Camera work fine. Grazie Maestro.
  5. #103
    umh...
    I still have the cyano camera and now works
    try to go to settings->app->all->search camera (the one of size 3.10MB) and tap on clear cache and clear data and restart the phone
    Ultima modifica di PaoloW8; 21-08-15 alle 23:32
  6. #104
    Feb 2014
    No works, tomorrow i will flash include 3 wipe. Camera APP habe 3.05 MB in mi device.
  7. #105
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    umh...
    After install the path, I still have the cyano camera. Both camera work! THX!
  8. #106
    Feb 2014
    After clean flash both camera works. Grazie
  9. #107
    Aug 2015
    hi,i wanna know why i cannot change the first picture that are shown while the phone booting up,after i flash baseband 353.
    i used to change the first picture by flash a zip(has been uploaded as an attachment),and all i need to do is to repalce the file,splash.img,in the zip with a my own 24 bit bmp picture that has been turned upside down.but now it just show a penguin after i flash the logo zip.and if i flash the baseband ver 3.53 again,it will show the "nubia powered by android" logo.how to solve with this problem?
    File allegati
    Ultima modifica di momomo; 22-08-15 alle 17:49
  10. #108
    Quote Originariamente inviato da momomo Visualizza il messaggio
    but are you sure that splash.img is a normal bmp ?
    if I try to open it with gimp says unknown file (instead your file opens correctly)
    if check with a hexadecimal editor the header is completely different
    sorry but I never changed the splash screen so I don't know
    Immagini allegate
  11. #109
    Aug 2015
    off course i have changed its filename extension.so long as you change it back(*.bmp) you can see it.
    but it was a annoying problem.maybe i should get used to the offical logo.
    btw,i have found a bug.if you enable navigation bar,the battery light wonnt go out after you stop charging.it is always on.
  12. #110
    @momomo
    I read your answer in the notification mail that I received
    the file extension in linux is useless...linux use the header files to understand what kind of file is so it doesn't matter if it's .bmp or .img etc
    try with original splash.img...rename in splash.bmp and try to open with photoshop or paintnet or similar
    btw, for home led bug...I fixed it, just download the zip and flash without wipe
    cm12.1_V8_liblightfix.zip
