Pagina 21 di 31 primaprima ... 111920212223 ... ultimoultimo
Visualizzazione dei risultati da 201 a 210 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #201
    Quote Originariamente inviato da Pstelios Visualizza il messaggio
    Good morning and thanks for the great rom.
    The only problem i face is the hardware volume keys, when i press them i get the message: ui has stopped working....
    Any help?
    I have no problem with hardware volume keys
    you did a full wipe before flashing the rom ? you use the default theme ?
    Nubia Z7MAX
    Sep 2015
    I use the default theme, i wiped everything before installation, rom works fine except that annoying thing
  4. #203
    really strange, no one has ever talked about this issue
    you can try with carbon rom or blisspop rom (they are equal to cm12.1 but with many additional features), you can find the link in my signature
    Nubia Z7MAX
  5. #204
    May 2015
    Will it work flip case?
  6. #205
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    With V15 I've lost connection twice in two days. Coverage and wifi icon appear with a exclamation and no more connection. Solved by turning off and on data connection.
    This happened some versions ago but has come back with V15. Not sure if also with V14 since I only used for a couple of days.
    And not sure if it is related with latest radio updates (now in V3.59)
    Has somebody experienced this problem? Which radio are you using?
    Thank you.
  7. #206
    Jan 2015
    Nubia Z7 Max
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Thank you.
    I've been using V15 with 3.60 baseband since Paolo posted it with zero issues. The ROM seems pretty stable now. You could try upgrading your baseband to 3.60 and wiping cache and Dalvik cache, but I had no troubles with 3.59 either.
  8. #207
    link and changelog V16 in first page
    Nubia Z7MAX
  9. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (09-10-15),jadar (09-10-15),LiveMoto (10-10-15),migel121 (08-10-15)
  10. #208
    Jul 2015
    Thanks! Where can download the stock firmware 3.61 (included in the rom?)
  11. #209
    Quote Originariamente inviato da oliverkof Visualizza il messaggio
    3.61 stock: 360?? - ????
    Nubia Z7MAX
  12. #210
    Aug 2015
    hello, i use V16. when use xposed v75. the phone is stop in bootanimation。。
    back to v15,it can start。
