Pagina 19 di 31 primaprima ... 9171819202129 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #181
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    Hi Paolo and thanks for your great work
    However, I have a bug report for V13: when the screen is unlocked and a call is incoming (the white popup at the top of the screen; sorry, I tried to put a screenshot here but the forum software doesn't seem to let me), only the number is displayed and not the contact name. When the screen is locked and an incoming call happens everything works fine.
    I believe it's a regression since V11 didn't have the bug.
    you use the default theme ?
    I just tried now and seems to work well
    Nubia Z7MAX
    Jan 2015
    Nubia Z7 Max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Yes, default theme and upgraded from V11. I just downgraded back to V11 and it works again. Anything I can do to help diagnose this?
  4. #183
    umh...I really don't know
    you have the contacts on gmail or on phone local account ?
    if you can try to flash the V13 with a full wipe and use the gapps from opengapps (arm, 5.1, nano)
    Nubia Z7MAX
  5. #184
    Jan 2015
    Nubia Z7 Max
    I'm syncing contacts from one gmail and one exchange account. I can try the full wipe later this week, but I can't really afford the time to set everything up again right now Thanks for the help Paolo!
  6. #185
    yes, I know
    if you're using the old gapps (tk_gapps-modular-nano-5.1.1-20150816-signed.zip) you can try to update only gapps with the opengapps version
    Nubia Z7MAX
  7. #186
    Jan 2015
    Nubia Z7 Max
    yes, I know
    I tried once more today. I installed the new gapps you mentioned, booted V11, and then installed V13 over that. Everything works now, but I have no idea why. Anyway, thank you very much Paolo!
  8. #187
    Jul 2015
    I found baseband 358 and 359 in your mega. Can they be used?
  9. #188
    nice
    Quote Originariamente inviato da oliverkof Visualizza il messaggio
    yes
    Nubia Z7MAX
  10. #189
    Nubia Z7MAX
  11. #190
    V14 and changelog in first page
    Nubia Z7MAX
  12. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (23-09-15),jadar (22-09-15)
