Pagina 30 di 31 primaprima ... 2028293031 ultimoultimo
Visualizzazione dei risultati da 291 a 300 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #291
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    link rel V22 in first page
    Hi Paolo! Can you sync to github last config sources 12.1?
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    done
    Nubia Z7MAX
  4. #293
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    done
    Only one different file
    I compiled the firmware to the latest sources cyanogenmod - in the settings menu items disappeared Show network speed in status bar, Superuser indicator etc. Do you know why?
  5. #294
    to add these features I have patched the source code of cm12.1
    you need to install the patches that you can find in the device/patch
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (11-07-16)
  7. #295
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Ok, thank/ I will try.
  8. #296
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Can't apply patch headset_6.patch:
    Adding Files if not exist...
    fatal: patch on the damaged line 28
    stat_sys_headset.xml added
  9. #297
    umh...let me check
    Nubia Z7MAX
  10. #298
    ok, I don't know why it doesn't work...I need to do some test
    btw, just donwload this file and copy in your sourcecode inside the directory frameworks/base/packages/SystemUI/res/drawable/
    Nubia Z7MAX
  11. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (19-07-16)
  12. #299
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Now all is ok! Firmware compiled.
  13. #300
    Oct 2016
    Hi there!
    Is it possible to flash the newest baseband 3.86 with this rom? I read in an Samsung related post, that you must not flash basebands that are newer than the rom.
    If it is possible, do i have to make some wipes?
    Regards
