Pagina 29 di 31 primaprima ... 192728293031 ultimoultimo
Visualizzazione dei risultati da 281 a 290 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #281
    sorry but I don't know, I have no problem to compile cm12.1...maybe it messed something in your sources
    to me the camera (snap camera) in cm13 works well, no problem to save images in the internal and external memory
    Nubia Z7MAX
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I was the brush you provide the CM13, the camera is in the electronic aperture can not save photos. I give my local_manifests to you, help me to see, where is wrong?
    <?xml version="1.0" encoding="UTF-8"?>
    <manifest>
    <project name="CyanogenMod/android_device_qcom_common" path="device/qcom/common" remote="github" revision="cm-12.1" />
    <project name="CyanogenMod/android_hardware_qcom_fm" path="hardware/qcom/fm" remote="github" revision="cm-12.1" />
    <project name="Christopher83/arm-cortex_a15-linux-gnueabihf-linaro_4.9" path="prebuilts/gcc/linux-x86/arm/arm-cortex_a15-linux-gnueabihf-linaro_4.9" remote="github" revision="master" />
    <project name="PaoloW8/android_device_nubia_nx505j" path="device/nubia/nx505j" remote="github" revision="cm12.1" />
    <project name="PaoloW8/android_vendor_nubia_nx505j" path="vendor/nubia/nx505j" remote="github" revision="cm12.1" />
    <project name="PaoloW8/android_kernel_nubia_nx505j" path="kernel/nubia/nx505j" remote="github" revision="cm12.1" />
    </manifest>
  4. #283
    Nov 2015
    repo init -u git://github.com/CyanogenMod/android.git -b cm-12.1
  5. #284
    Feb 2016
    hi I am an user of Z7 max from China,first, thanks a lot for your creativity and insist on Z7 max.
    here is a problem I found when the latest CM12.1 (v21)run in my Z7 max, when I am trying to choose a song to replace the default one for Alarm clock,
    items of the songs in SD or Internal memory all displayed grey and being Not selectable, no matter mp3 ,or any songs of other type else.
    This problem happened since V18, please help and find if it can be fixed.
    by the way, apologize for my poor English.
  6. #285
    Mar 2016
    I think your CM12.1 is very good!It makes my Z7 Max work well.
    Will this CM12.1 continue to update? Especially get March update?
    Thank you!
  7. #286
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Please upgrade to V22! Thank you!
    4PDA community from Russia
  8. #287
    link rel V22 in first page
    Nubia Z7MAX
  9. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (14-04-16),jadar (26-04-16),LiveMoto (18-04-16),Pstelios (14-04-16)
  10. #288
    Sep 2015
    Hi Paolo, do you consider to make further improvements on this 12.1 rom? Thanks for your work, anyway
  11. #289
    Feb 2016
    Will update from v21 to v22 erase data and apps on the phone?
  12. #290
    Quote Originariamente inviato da WywernPL Visualizza il messaggio
    no if you only wipe cache and dalvik cache
    Nubia Z7MAX
