Pagina 28 di 31 primaprima ... 182627282930 ... ultimoultimo
Visualizzazione dei risultati da 271 a 280 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #271
    next week I will update the cm12.1 but sorry...only the cm12.1
    Nubia Z7MAX
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (13-12-15)
    Nov 2015
    Anybody knows Where i can turn Radio On in Secret settings ?
  5. #273
    link and changelog release V19 in first page
    Nubia Z7MAX
  6. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (16-12-15),LiveMoto (18-12-15)
  7. #274
    dve
    dve non è in linea
    Dec 2015
    Hi Paolo, thank you for your work.
    Do you can add fuse in kernel?
  8. #275
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Hi Paolo! More updates will not be?
    Completion CM12 is completed?
    From my remaining problems:
    - If you receive a call, the caller hears me after 1 second. Because of this, he misses my phrase, "Yes, I am in touch", "Hi" or "Hello".
    Thank you for the work Paolo!
    Ultima modifica di LiveMoto; 22-01-16 alle 08:06
    4PDA community from Russia
  9. #276
    link release V20 in first page
    Nubia Z7MAX
  10. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (24-01-16)
  11. #277
    Sep 2015
    Thanks Paolo!
  12. #278
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Paolo, new year is good! Can you upload your V20 code? I was always wrong when compiling CM12.1. Thank you very much!
  13. #279
    Link release V21 in first page
    Nubia Z7MAX
  14. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (12-02-16)
  15. #280
    Nov 2015
    target StaticLib: third_party_webrtc_modules_video_render_module_gyp (/home/syai2012/rom/cm12/out/target/product/nx505j/obj/STATIC_LIBRARIES/third_party_webrtc_modules_video_render_module_gyp _intermediates/third_party_webrtc_modules_video_render_module_gyp .a)
    build/core/host_executable_internal.mk:31: recipe for target '/home/syai2012/rom/cm12/out/host/linux-x86/obj32/EXECUTABLES/third_party_libvpx_libvpx_obj_int_extract_arm_host _gyp_intermediates/libvpx_obj_int_extract' failed
    make: *** [/home/syai2012/rom/cm12/out/host/linux-x86/obj32/EXECUTABLES/third_party_libvpx_libvpx_obj_int_extract_arm_host _gyp_intermediates/libvpx_obj_int_extract] Error 1
    make: *** 正在等待未完成的任务....
    target StaticLib: third_party_usrsctp_usrsctplib_gyp (/home/syai2012/rom/cm12/out/target/product/nx505j/obj/STATIC_LIBRARIES/third_party_usrsctp_usrsctplib_gyp_intermediates/third_party_usrsctp_usrsctplib_gyp.a)
    target StaticLib: third_party_libjingle_libpeerconnection_gyp (/home/syai2012/rom/cm12/out/target/product/nx505j/obj/STATIC_LIBRARIES/third_party_libjingle_libpeerconnection_gyp_interm ediates/third_party_libjingle_libpeerconnection_gyp.a)
    #### make failed to build some targets (20:38 (mm:ss)) ####
    Paolo,I am in the compilation of this error, the compilation method and before the same, I would like to ask what is the reason? In addition, the CM1`3 camera in the electronic aperture can not save the photos, meaning that, can take pictures, but the photos did not save, I try to change the storage location into the built-in, but still not.
