Utente del mese: megthebest con ben 15 Thanks ricevuti nell'ultimo mese
Pagina 3 di 31 primaprima 1234513 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #21
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I did a lot of tests and I was unable to replicate this problem
    thank you for your reply.
    the problem will happen when the proximity detects the face and turns off the screen. you can block the proximity sensor during a call and hang up from the other side such that the problem will occur.
    Many thanks!
    Quote Originariamente inviato da no1chan Visualizza il messaggio
    Many thanks!
    yes I have already tried several time (I call the z7max with another phone and hang up with the screen off by proximity sensor) but nothing
    you have tried with the option "prevent accidental wake-up" off in settings->display & light ?
  4. #23
    Jul 2015
    originally the option "prevent accidental wake-up" was on and i had that problem.
    i just turned this option off and tested it again. the problem still exists.
    in fact this problem can be solved by switching "double tap to wake" off. but i would like to use the "double tap to wake" function. thank you for your help.
  5. #24
    you can post a screenshot of the properties of the file "/data/tp/easy_wakeup_gesture" ? I need to know which touchscreen you have (there are 2 or more types of touchscreen)
    you can do with the cm file manager (after enable root) or root explorer
  6. #25
    Jul 2015
    when i switch on the function "double tap to wake", the value in the file "/data/tp/easy_wakeup_gesture" is 0x01 as shown below.
    when "double tap to wake" if off, the value becomes 0x00.
    thank you for your attention.
  7. #26
    yes is right
    but i need the properties of the file like this
  8. #27
    Jul 2015
    yes is right
    sorry for misunderstanding you
  9. #28
    Jul 2015
    don't why that screenshot is so small...
    Immagini allegate
    Ultima modifica di no1chan; 27-07-15 alle 08:59
  10. #29
    yes is too small, i can't read the Link lines
    or you use a web site to host the image (like Imgur) or write the link line
  11. #30
    Jul 2015
    try this
  12. Il seguente Utente ha ringraziato no1chan per il post:
    PaoloW8 (27-07-15)
