Pagina 5 di 31 primaprima ... 3456715 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #41
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    I just installed v4. Will let you know if any problems occur
    In the meantime, I had a question -- older Android versions had a setting for custom Date & time formatting and I see this setting is mostly gone in newer versions and the OS pulls the Date & time settings for the language chosen in Language & input. I personally like to use the ISO date format but it isn't available. Any chance this could be added or do you know of any application that does custom Date & time formatting?
    umh...I don't know if is possible to implement, I see if I can find some information.
    I looked at the market and I found no app for this setting
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    Thanks for you update.
    The V4 is working like a charm, very smooth. I think it is because of the linaro toolchain .
    Can you also do more optimization on the kernel? for example can you backport the ZRAM feature to the 3.4 kernel from higher base line of the kernel.
    https://git.kernel.org/cgit/linux/ke...740bac5670d18b
    if you want to try the kernel with zram support download and flash this zip (without wipe)
    cm12.1_zramkernel.zip
    zram is disabled by default but you can enable with trickster mod app
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    securecrt (04-08-15)
  5. #43
    Jan 2015
    Nubia Z7 Max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    So did I and found nothing. Don't bother too much, it's not crucial, it was just a question -- you know much more about the inner workings of Android than anyone else I can contact. Thanks!
    Also, a report: the fix for the bright LED didn't completely take: I got it a few hours ago while reading Reddit through the Relay app. I can't reliably reproduce it, though.
  6. #44
    for those who have the touch bug try with this kernel
    from the first tests seems to work
    (flash without wipe)
    cm12.1_kernel_test6.zip
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    no1chan (04-08-15)
  8. #45
    Jul 2015
    This work! Thank you very much for your great work! I can fully give up official rom! Thank you!
  9. #46
    Jul 2015
    I think you just have enabled the ZRAM option in the Makefile, I have the experiance of using zram in other phone(Samsung Galaxy S2) I know the current zram code has some unstable issues, anyway I will testing the kernel first and feedback to you the results.
    == edit after installed the new kernel ===
    I have enabled 384MB zram , now it is working , I can have more apps in the cache most of the apps can stay in the ram and reduced much more loading time, Now the phone has better user experiance than before, but I need to test more time to see the stablity.
    Ultima modifica di securecrt; 04-08-15 alle 06:48
  10. #47
    Jul 2015
    goooooooooooooooooooooooooooood
    i think the problem is solved by flashing this kernel!!!
    Ultima modifica di no1chan; 04-08-15 alle 06:46
  11. #48
    zram is already present in codeaurora kernel, I added the lz4 support (for better compress/uncompress speed) and enabled
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
  13. #49
    Quote Originariamente inviato da no1chan Visualizza il messaggio
    ehehe nice
  14. Il seguente Utente ha ringraziato PaoloW8 per il post:
    no1chan (04-08-15)
  15. #50
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Paolo! In V4... I observed performance gains. AnTuTu outstanding results 45858 and 21811 issued AnTuTu HTML5 test.
    Thank you for your excellent work.
    I also want to tell about the malfunction LED illumination range, if the charge is less than 14%. The circle blinks very dim light. Side buttons are lit at the same time at full brightness. It looks undignified. Moreover, not found possible to adjust the frequency range of the pulsations during charging. in CM12 was previously a function (not on your build).
    Thanks to you, I can enjoy the new Android and Material Design style.
    Ultima modifica di LiveMoto; 04-08-15 alle 10:21
    4PDA community from Russia
