Utente del giorno: Palcamil con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 13 di 31 primaprima ... 3111213141523 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #121
    Quote Originariamente inviato da zrnokia5230 Visualizza il messaggio
    hellow paol.
    i have some questions here.
    1.i heard from u that " in YIOS the thermal engine it is not working properly and consequently the frequency of the CPU and GPU remains low (which is why AnTuTu score is 30k-35k)
    however in this rom the thermal engine works properly, the frequencies are raised and obviously also increases the heat"
    what's the thermal engine? u mean if it is not working properly , it can't use themes? when i use yios, it can change themes , i want to know which features would be affected because of thermal engine is not work.
    2. when i use v6 v7 v8 . i am not test for otg feature.
    when i use v9 , otg is not work, when use U disk, U disk‘s lights are not flashing,and phone can't found udisk..
    when i use usb Mouse, it's lights are flashing but no arrows on the phone screen.
    when i use YIOS , otg is work OK.. if because of i flasing your rom with out full wipe??
    1. thermal engine is the service that manages the CPU clock frequencies based on the temperature, It has nothing to do with the theme engine
    sure you can use themes
    2. I tried now OTG with a usb key and works well (sorry but i can't try now with a mouse)
    yes...update from yios may not work properly, if you can try with a full wipe (also format system)
    Aug 2015
    Thanks for your quick response.
    I remember from yios to your rom(v6),I have tried a full wipe wipe with a clean install of v6
    but from v6 to v7 to v8 to v9 ,i am not do full wipe..
    in yios forum,others use ur v9,otg is also work well.. maybe my OTG line is not work.. I'll test it later..
    and can u add this features like this pic? (forgive my poor english)QQ截图20150827164312.jpg
  4. #123
    Aug 2015
    Hi I lost by flashing a baseband!I trayed to flash the baseband_354 but it the basebant do not work! Can I do somthing? Thanks
  5. #124
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    link Release V9 and changelog in first page
    I think the V10 is on the way 3.55 baseband .
  6. #125
    Quote Originariamente inviato da shikip Visualizza il messaggio
    I'm sorry but if you do not say more about what you've done is hard to help
    you mean you lost the IMEI ?
  7. #126
    Jan 2015
    Hello,
    I want make a clean install of the V9.
    Can I install V9 with the 3.55 baseband ?
    thks
  8. #127
    Yes you can
    Nubia Z7MAX
  9. #128
    V10 in first page
    Nubia Z7MAX
  10. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    LiveMoto (31-08-15),securecrt (31-08-15)
  11. #129
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    V10 in first page
    Big thanks! Good job!
    4PDA community from Russia
  12. #130
    I have also compiled the Carbon Rom, if anyone wants to try it can be found here: https://www.androidiani.com/forum/zt...nofficial.html
    Nubia Z7MAX
