Pagina 4 di 31 primaprima ... 2345614 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #31
    Quote Originariamente inviato da no1chan Visualizza il messaggio
    ok thanks
    you have the synaptics touchscreen digitizer (different from what I have)
    I think the problem is in the kernel driver, I try to see if I can understand something
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    no1chan (27-07-15)
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    ok thanks
    in fact there are many users suffering from this problem. you can find a lot of threads discussing it in the nubia forum.
    also you have been very famous in that forum because of your great rom.
  5. #33
    if I send you a new kernel you can test ?
    I can't test because I have a different touchscreen
  6. #34
    Jul 2015
    of course i can do the test. please tell me how to do
  7. I seguenti 2 Utenti hanno ringraziato no1chan per il post:
    bubbl3 (31-07-15),PaoloW8 (27-07-15)
  8. #35
    ok, I send you a PM with link and instruction
  9. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    bubbl3 (31-07-15),no1chan (27-07-15)
  10. #36
    Jul 2015
    Hi! Dear paolothlw8, appreciate your contribution to the world.
    I must say I haven't yet flashed this Rom, since I am waiting that key problem to be solved, as well as a possible power draining problem common to Android 5.x.
    But before that, I guess this Rom will also have interface problem on Dual Sim as original/yios, so I want to give a suggestion for your consideration:
    Most Dual Sim phone hasn't yet been optimized, and just provide one phone button, and thus requires 3 Clicks in the process: Open Phone Icon + Call + Select Sim.
    In case users need to use some bad integrated software like Skype, which may request selection repeatedly, up to 5 clicks may be required in order to make phone call successfully: Open Phone Icon + Call + Select Sim + Select between Phone & Skype (initiated by Skype) + Re-Select Sim (initiated by Skype).
    The best solution I have seen from a Dual-Sim phone is: Providing 2 Phone Icons. Any call made from 1/2 icon will normally by corresponding Sim1/Sim2, unless special preset.
    The normal process can be reduced from 3 clicks to 2 clicks: Open Phone Icon with Desired-Sim + Call
    The process (with Skype installed) can be reduced from 5 clicks to 3 clicks: Open Phone Icon with Desired-Sim + Call + Select between Phone & Skype. (Skype won't request Re-Select Sim in this case, since Skype now don't know we have Dual Sims)
    Similar concept may also apply to Contact Icon.
    To unify the usage experience, personally I usually more prefer using Contact Icon, instead of Phone Icon. Because Contact Icon provide more DIRECT & FLATTEN choices like Skype, Whatsapp, ... This can reduce the no. of clicks, and let me to decide which communication mode to use after selecting the suitable contact person.
  11. #37
    I already answered a few days ago to a question like that here: https://www.androidiani.com/forum/in...ml#post6984380
    I don't know if the cyanogen team is planning to improve the dialer and the dual sim support
  12. #38
    link and changelog release v4 in first page
  13. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    LiveMoto (04-08-15),no1chan (03-08-15),securecrt (03-08-15)
  14. #39
    Jan 2015
    Nubia Z7 Max
    I just installed v4. Will let you know if any problems occur
    In the meantime, I had a question -- older Android versions had a setting for custom Date & time formatting and I see this setting is mostly gone in newer versions and the OS pulls the Date & time settings for the language chosen in Language & input. I personally like to use the ISO date format but it isn't available. Any chance this could be added or do you know of any application that does custom Date & time formatting?
  15. #40
    Jul 2015
    Thanks for you update.
    The V4 is working like a charm, very smooth. I think it is because of the linaro toolchain .
    Can you also do more optimization on the kernel? for example can you backport the ZRAM feature to the 3.4 kernel from higher base line of the kernel.
    https://git.kernel.org/cgit/linux/ke...740bac5670d18b
