Pagina 49 di 50 primaprima ... 3947484950 ultimoultimo
Visualizzazione dei risultati da 481 a 490 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #481
    Feb 2017
    Hi !,
    When you make a custom kernel for the Z7 Max and Android 7? Missing overclocking the CPU and GPU, no choice CPU hotplug, should improve performance insert SQLite, there is no dynamic fsync and many others.
    Senior Droid L'avatar di ase11
    Ringraziato 47 volte in 44 Posts
    Quote Originariamente inviato da Caikki Visualizza il messaggio
    Nope, this twrp doesnt format or resize correctly for the crypto footer nor decrypt it
    Kernel doesn't encrypt on first try, just using terminal
    Thanks again
    @Caikki how do you encrypt using terminal? I mean...how do you access Terminal in Android? Thank you,
  4. Il seguente Utente ha ringraziato ase11 per il post:
    Caikki (14-02-17)
  5. #483
    Nov 2016
    South America
    NUBIA Z7 MAX, MOTO G2, S3 MINI
    Quote Originariamente inviato da trappenhuis Visualizza il messaggio
    You can use 3 kinds of terminal:
    1. Settings > About phone > touch Build Number 7 times to enable Developer options, go back.
    Settings > Developer options > Enable local terminal
    Terminal is now in your launcher.
    2. Download any Terminal emulator on Google Play/Apkmirror etc
    3. Settings > Developer options > Root access > ADB and apps
    Connect phone to a PC with Android sdk platform tools or Minimal ADB & Fastboot, open terminal from the folder adb.EXE is located then enter command
    codice:
    adb root
    , confirm access key on your phone then enter command
    codice:
    adb shell
    Then encryption commands are
    codice:
    su
    codice:
    vdc cryptfs enablecrypto <inplace or wipe> <default or pattern or pin or password> <your password (must be 4-36 characters long)>
    If you are using Z7 Max' TWRP default partition size (689631 blocks), only 4 blocks are free I guess so encryption only works with 4 character passwords.
    Also note only Paolo's CM13 beta 1, 2, 3~7 can encrypt successfully. Beta 8 onwards encryption is broken, but it can decrypt successfully storage encrypted with earlier releases :s
    Ultima modifica di Caikki; 14-02-17 alle 05:39
  6. Il seguente Utente ha ringraziato Caikki per il post:
    ase11 (14-02-17)
  7. #484
    How to resize partition to be able to use at least 6 chars password? Thanks.
  8. Il seguente Utente ha ringraziato ase11 per il post:
    Caikki (14-02-17)
  9. #485
    Nov 2016
    South America
    Backup your storage files,
    Backup your appdata with Titanium Backup
    Assuming you're using ext4 data
    Boot to TWRP > Advanced > Terminal
    Enter
    codice:
    umount /dev/block/mmcblk0p23
    codice:
    e2fsck -f /dev/block/mmcblk0p23
    codice:
    resize2fs -f /dev/block/mmcblk0p23 6896600
    Remember if you are on z7 max only CM13 beta7 or earlier is able to encrypt.
    Once your device is encrypted, any z7 max TWRP still not able to access internal storage, you need an external SD to install latest CM13 (V17) with gapps (only wipe cache and system to do so, if you wipe data, encryption is gone)
  10. Il seguente Utente ha ringraziato Caikki per il post:
    ase11 (14-02-17)
  11. #486
    do you see a big hit on performances with encryption on?
  12. #487
    Nov 2016
    South America
    Nothing at all, I always have 1GB free, 700MB at most. Also, with a quad 2.4GHz we wouldn't feel a thing.
    I'm not a heavy user really, my most demanding app ever was Pokemon Go. It never lagged on me
  13. #488
    Feb 2016
    is there a solution for mobile data or that edge bug is still present? I didn't read much and that bug is the main reason I'm still on stock rom
  14. #489
    Quote Originariamente inviato da MonkPsycho Visualizza il messaggio
    what bugs you talking about?
    Nubia Z7MAX
  15. #490
    Feb 2016
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    When I turn on 3g data connection, doesn't matter on which sim, it's always on edge, whilst on stock rom I get h+ on the same location.
    That's the main reason I still run stock rom...
    3rd page on needrom
    I have a problem. My second sim is for Internet. I cant change the networktype. It stays always on global. And a have only gsm or edge. With original rom, i have h+ or lte.
    Log in to reply.
    04/18/2013
    [Italy]
    paolothlw8 on 11/11/2015 @ 9:16 pm Author ad
    yes the select network type for the moment is bugged
    you can try to switch in "gsm only"the first sim: open the dialer and compose the number *#*#4636#*#*->phone information->set preferred network type to gsm only
    after that go in settings->sim cards and switch cellular data to sim 2
    settings->more->cellular network->card2->preferred network type and select the first options and wait 1 minute
    if not work you can try to search network operators
    Ultima modifica di MonkPsycho; 06-03-17 alle 01:03
