That worked! Thank you very much! I noticed that if i turned off the expression recognition(that little smile next to the settings cog) the front camera stopped crashing and worked properly, so that was what it was missing.
I discovered 2 more minor issues. Messenger, facebook and probably more social networking apps fc at login time, an issue i fixed by substituting libssl.so and libboringssl-compat.so from your cm builds. Your files fully fixed it, although i would be great to have them fixed at the source level. What i also discovered today, is that my build fails the 3d part of antutu benchmark every time by crashing the 3dbench application at random times. I tried a few 3d games and they play fine, so i don't consider it to be that big an issue, apart from the much lower antutu bench scores(about 40000 without the 3d part). I tried 3dmark and it worked ok, except for the part with the offscreen rendering, so that could be a lead to fix the problem.
On the upside, i tried a fix i found on the 4pda forum for the bluetooth music, removing hci_qcomm_init from the vendor folder and i have not encountered stuttering on a2dp yet, although i didn't have time to test it throughly. The random reboots that cm13 rel v10 had on high accuracy location mode are also completely gone as well, i tested pokemon go(which was unplayable on rel 10) and it played fine and rock stable. You probably have that fixed on rel 11 though. Thank you for your contribution and your help, hope you can take some time to help a fellow in learning the inner workings of android!
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di PaoloW8; 10-08-16 alle
