Pagina 2 di 19 primaprima 123412 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #11
    Nov 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    Thanks!paolo
    When taking pictures, you can not save the photos, you have this fault?
    Nov 2015
    DEVICE and VENDOR the two folders of the source code is how to generate? I would like to try to compile z7 Nubia (NX506J), there is no relevant tutorial? Thank you!
  4. #13
    Nov 2015
    Thanks!paolo
  5. #14
    yes you are right, strange because some days ago it worked
    I do some checking
    there is no tutorial to generate device and vendor, you can use the tree from a similar device (like nx505j) but surely there will be things to be changed
    and you also need the kernel source code of the new device
    Nubia Z7MAX
  6. #15
    Jul 2016
    Great work paolo! Cant wait to get working on nougat too once resurrection remix sources are out! Right now im busy trying to get gionee elife e7 work with marshmallow, and the camera turn out to be a real bummer .
    For the Nubia z7(nx506j), i have made an attempt to port marshmallow to it, using z7 max files(paolo's tree with some of my modification for rr), you can find my files here: https://mega.nz/#F!s0YBSSLY!s6fX3aLbvvOaFj9otI_wDA . It contains a recovery and rom i built with a mostly adapted z7 max kernel(zte did not release sources for the lollipop kernel for nx506j) with some modifications and files from the kitkat nx506j sources.Blobs are from 3.83 firmware,if you try this and it works i can try to update them to 3.86 firmware.
    No device to test it, so do as you want with the files. Also uploaded my sources on github(since someone has any desire to try anything for the nx506j) here: https://github.com/MrPink7
  7. #16
    Nov 2015
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    Thanks!Thanks!
  8. #17
    Nov 2015
    [QUOTE=paolothlw8;7667443]yes you are right, strange because some days ago it worked
    I do some checking
    Is the camera problem solved? How did you solve it? Hope to get your help,
  9. #18
    [QUOTE=awssong;7668249]
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    yes you are right, strange because some days ago it workedI do some checkingIs the camera problem solved? How did you solve it? Hope to get your help,
    yes fixed now I'm not at home but in a few hours I update my github with the fix
    Nubia Z7MAX
  10. #19
    Nov 2015
    [QUOTE=paolothlw8;7668391]
    I see,Thanks!
  11. #20
    rild crash fixed !!
    I need to do few more tests but now works
    Nubia Z7MAX
  12. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (04-10-16),mai62 (03-10-16)
