Pagina 12 di 19 primaprima ... 21011121314 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #111
    Nov 2016
    ZTE Z5 Mini
    Can someone help me to port CM14.1 to Z5 Mini, i´m trying but getting a lot of errors?, Thanks for the help
    Jul 2015
    After installing Open GApps (Stock package, including launcher, contacts, dialer etc.), is it safe if I remove Cyanogenmod's Trebuchet launcher, official contacts, dialer, AudioFX etc. from ROM ?
  4. #113
    Quote Originariamente inviato da patwwh Visualizza il messaggio
    I don't know, never tried
    Nubia Z7MAX
  5. #114
    link cm14.1_beta3
    changelog:
    26/11/2016 beta3 (MD5: 3a54ca612bb36dcdf90328cd00507211)
    • kernel: few fix
    • sync cyanogen source code (26/11/2016)
    Ultima modifica di PaoloW8; 26-11-16 alle 21:53
    Nubia Z7MAX
  6. #115
    Nov 2015
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    link cm14.1_beta3
    changelog:
    • kernel: few fix
    [ 52% 18064/34481] Download: /home/sya...rmediates/org.cyanogenmod.gello-40.apk
    FAILED: /bin/bash -c "(mvn -q org.apache.maven.plugins:maven-dependency-plugin:2.10:get org.apache.maven.plugins:maven-dependency-plugin:2.10:copy -DremoteRepositories=central::::https://maven.cyanogenmod.org/artifa...ello_prebuilds -Dartifact=org.cyanogenmod:gello:40:apk -Dmdep.prependGroupId=true -Dmdep.overWriteSnapshots=true -Dmdep.overWriteReleases=true -Dtransitive=false -DoutputDirectory=/home/syai2012/rom/suda3/out/target/common/obj/APPS/Gello_intermediates/ )"
    [ERROR] Failed to execute goal org.apache.maven.plugins:maven-dependency-plugin:2.10:get (default-cli) on project standalone-pom: Couldn't download artifact: Could not transfer artifact org.cyanogenmod:gello:apk:40 from/to central (https://maven.cyanogenmod.org/artifa...lo_prebuilds): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    [ERROR] org.cyanogenmod:gello:apk:40
    [ERROR]
    [ERROR] from the specified remote repositories:
    [ERROR] central (https://repo.maven.apache.org/maven2, releases=true, snapshots=false),
    [ERROR] central (https://maven.cyanogenmod.org/artifa...ello_prebuilds, releases=true, snapshots=true)
    [ERROR] -> [Help 1]
    [ERROR]
    [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
    [ERROR] Re-run Maven using the -X switch to enable full debug logging.
    [ERROR]
    [ERROR] For more information about the errors and possible solutions, please read the following articles:
    [ERROR] [Help 1] http://cwiki.apache.org/confluence/d...utionException
    [ 52% 18064/34481] target R.java/Manif...PS/LatinIME_intermediates/src/R.stamp)
    Warning: AndroidManifest.xml already defines minSdkVersion (in http://schemas.android.com/apk/res/android); using existing value in manifest.
    Warning: AndroidManifest.xml already defines targetSdkVersion (in http://schemas.android.com/apk/res/android); using existing value in manifest.
    [ 52% 18064/34481] Building with Jack:...l_intermediates/with-local/classes.dex
    ninja: build stopped: subcommand failed.
    build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
    #### make failed to build some targets (01:06:46 (hh:mm:ss)) ####
  7. #116
    Nov 2015
    link cm14.1_beta3
    changelog:
    • kernel: few fix
    The problem out in the compilation of Gello, the shield will be able to compile it, how do you solve the problem?
    # Browser
    PRODUCT_PACKAGES += \
    #Gello
    # Filesystem
    make_ext4fs
  8. #117
    gello is a precompiled apk
    when you compile the full rom gello.apk is downloaded from the cyanogen server so a internet connection is required during the compile process.
    Nubia Z7MAX
  9. #118
    Jul 2016
    Thank you paolo, managed to build RR N today thanks to you. Most stuff works fine, which is surpising considering cm14.1 hit official status just 15 days ago. Had to use a memory patch to java to build with my meager 8gb of ram . The only thing i noticed is that photos taken from the front camera are inverted(mirrored). New module-less kernel works great.
    Simple question: Can i make marshmallow build with openjdk-8? I have to remove 7 completely because i had errors with compiling Nougat.
  10. #119
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    sure, I compile the cm13.0 with openjdk-8 without problem
    you can add this line in your <home>/.profile file:
    codice:
    export EXPERIMENTAL_USE_JAVA8=true
    (or write in your terminal before the brunch command)
    Nubia Z7MAX
  11. #120
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    link cm14.1_beta3
    changelog:
    • kernel: few fix
    Hi, Paolo!
    On CM14.1 my phone have the same problem as CM13 - phone call disconnected after few minute.
    CM12.1 - no problems/
