Pagina 4 di 19 primaprima ... 2345614 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #31
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Bugs: not work a proximity sensor, when take away the phone from ear.
    the display doesn't turn off when you cover the sensor ?
    I tried now and to me it works well
    edit
    you can try with sensor test if the proximity sensor works ? and tell me if the vendor is Nubia or QTI
    Ultima modifica di PaoloW8; 07-10-16 alle 12:55
    Nubia Z7MAX
    Nov 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    Thanks!paolo
    export JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation -Xmx4096m"
    out/host/linux-x86/bin/jack-admin kill-server
    out/host/linux-x86/bin/jack-admin start-server
    This can be added to the system configuration files? Otherwise, every time the compiler to perform once, too much trouble, and the compiler will be interrupted. Thank you
  4. #33
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    edit
    the display doesn't turn on, when I uncover the sensor.
    Vendor is Nubia v.1
  5. Il seguente Utente ha ringraziato brooklyn2006 per il post:
    PaoloW8 (07-10-16)
  6. #34
    no is not possible.
    you can add the line
    codice:
    in your .profile file in your home directory but you still need to launch
    codice:
    every time you compile
    edit:
    or just update your PC with 16GB ram
    Ultima modifica di PaoloW8; 07-10-16 alle 14:34
    Nubia Z7MAX
  7. #35
    Vendor is Nubia v.1
    ok thanks
    strange, I have no problem with the proximity sensor but I will check if there is something wrong
    Nubia Z7MAX
  8. #36
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Hi, Paolo!
    When do you plan make next build?
  9. #37
    Hi, Paolo!
    today or tomorrow
    Nubia Z7MAX
  10. #38
    I fixed the video recording
    it's a experimental fix but seems to work
    today I will upload the alpha3
    Nubia Z7MAX
  11. #39
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Great news!
    What's about proximity sensors?
  12. #40
    Nov 2015
    The system comes with the file manager to open the external memory card, prompted the need for ROOT users, but through the download menu can be opened
