Pagina 87 di 97 primaprima ... 37778586878889 ... ultimoultimo
Visualizzazione dei risultati da 861 a 870 su 967
Jiayu G2F
  1. #861
    Androidiano L'avatar di Negativeland
    Sep 2013
    Ciao
    Mi chiarite per favore.?
    Il link corretto é qquesto? https://drive.google.com/file/d/0B1E...eFk/view?pli=1
    Va bene con miui che con stock?
    Jiayu G2Fw
    Quote Originariamente inviato da Negativeland Visualizza il messaggio
    Ciao
    Con Miui ti confermo che va benissimo,penso che con stock va bene.
  4. #863
    Sep 2013
    Quote Originariamente inviato da coisf Visualizza il messaggio
    Grazie provo e ti faccio sapere
  5. #864
    Jun 2015
    I'm on stock W-R-0.3.6 ROM!
  6. #865
    @blackbible
    Please tried this boot.img version (0.3.6 - fully unlocked).
    Zippyshare.com - Jiayu--G2F-W-kernel-0.3.6b-compass-fix-unlocked.zip
  7. #866
    Jun 2015
    @blackbible
    What is it? What is the difference?
  8. #867
    It's unlocked kernel
    default.prop changes
    # ADDITIONAL_DEFAULT_PROPERTIES
    ro.secure=0
    ro.allow.mock.location=0
    persist.mtk.aee.aed=on
    ro.debuggable=1
    persist.sys.usb.config=mass_storage
    persist.service.acm.enable=0
    persist.service.adb.enable=1
    ro.mount.fs=EXT4
  9. #868
    Jun 2015
    Hello, thanks, but I don't need it.
  10. #869
    Do you the mean the use of a unlocked kernel? Are you sure?
    If you want to make a real FULL rooy you need it. Ex. usefull to create yourself CXWM/TWRP.
    No one can bypass limitation of the kernel (boot.img) voia sofwtare.
    You can just make changes on teh image and rebuild it.
  11. #870
    Jun 2015
    I have root, I have CWM.
    I unpacked the boot.img and edited the init.rc than packed back and flashed - it is working, the freezing problem solved!!!
