Pagina 41 di 99 primaprima ... 3139404142435191 ... ultimoultimo
Visualizzazione dei risultati da 401 a 410 su 982
[UFFICIALE] Viber | Info, Dubbi e Domande
  1. #401
    Androidiano L'avatar di Viber
    Ringraziato 28 volte in 28 Posts
    Quote Originariamente inviato da kronos666 Visualizza il messaggio
    E' possibile che malgrado abbia disattivato l'app di Viber,chi mi chiama trova il numero libero,ma a me non squilla il telefono(anche perchè non ho più viber..)??
    Probabile che ci sia già stata la richiesta ma onestamente sono troppe pagine da rileggere,scusate.
    I am not sure I fully understood your question, but I will try to help: even when Viber is closed (shut off), it should still remain available for calls and messages, since it uses the C2DM service (operated by Google).
    Androidiano L'avatar di kronos666
    Nexus 4
    Thanks Viber for your reply!!
    But my problem is bit different,I try to explain you(sorry for my English):
    I have uninstalled Viber app,but my contact appears like available,and if someone call me,phone rings free to them but my phone doesn't ring.
    I hope that you could understand me.
    Regards.
  4. #403
    Yes, I think I understand
    Deleting Viber (as opposed to deactivating) makes it impossible to us (technically) to know whether or not that user intends to reinstall Viber later, or plans to stop using it altogether. This is why there is a wait of 45 days during which if we see no activity on the account, it is automatically deleted, and only then you will stop appearing as a Viber user to your contacts.
    The instant way to do it, however, is to deactivate Viber instead of uninstalling it. This is done through the "More" tab inside Viber.
  5. #404
    Nexus 4
    Thanks Viber,you have understood my problem. Ok now I'll waiting for some days to check my status on firend's device.
    Regards.
  6. #405
    Scusate, ma su viber a me non vibra il cell né all'arrivo di chiamate né di messaggi mentre per tutte le altre applicazioni la vibrazione funziona... è normale? Come posso fare?
  7. #406
    Quote Originariamente inviato da 123456789Elena Visualizza il messaggio
    Did you make sure that your phone's vibration settings are turned on?
    Also, please specify what phone you have, and which version of Android.
    Sei sicuro che le impostazioni di vibrazione del telefono è acceso?
    Inoltre, si prega di specificare quali telefono che hai, e che versione di Android.
  8. #407
    I'm sure that the vibration is turned on, and I have galaxy s3 no brand italia, versione 4.0.4
  9. #408
    Thank you for the details.
    Please use this direct link to report the problem to our Support Team, so they can find the source of the issue: Your ticket details | Viber Support
    Thank you in advance
    Grazie per i dettagli.
    Si prega di utilizzare questo link diretto per segnalare il problema al nostro team di supporto, in modo che possano trovare la fonte del problema: Your ticket details | Viber Support
    Grazie in anticipo
  10. #409
    Ciao a tutti,
    ho un lg p500 ( O1 con rom originale con permessi di root) ho notato che Viber (v. 2.2.3) utilizza circa 91 mb di memoria (impostazioni-applicazioni-processi in esecuzione), mentre su un lg e510 (hub) non supera i 40 mb di memoria, tutto questo si traduce nel fatto che, sul p500 la batteria che prima durava mediamente 36/48 ore, ora non arriva a 24 ore, pur rimanendo invariato l'utilizzo.
    C'è qualche impostazione che dovrei verificare?
    E' normale un assorbimento di questo tipo?
    Nei vostri cellulari quanta memoria utilizza?
  11. #410
    Napoli
    SE x10mp Nexus 1, Galaxy Nexus
    Ringraziato 79 volte in 71 Posts
    Purtroppo è così. Dall'aggiornamento ad ICS in poi Viber consuma tanta batteria. E non fatevi ingannare se nel co sumo batteria magari lo trovate con appena il 2 o 3%.... con Viber installato le "applicazioni di base android" (android core apps) a fine giornata arrivano da sole anche al 20% di consumo. Basta fare una prova.
    P.S.: l'ho sostituito con Freepp che funziona pure meglio!
