Pagina 193 di 574 primaprima ... 93143183191192193194195203243293 ... ultimoultimo
Visualizzazione dei risultati da 1,921 a 1,930 su 5732
[INFO][D855][NO MODDING]Thread per gli aggiornamenti software ufficiali (LG G3)
  1. #1921
    S22 Ultra,Find X2 pro,Mi 10
    Quote Originariamente inviato da TheHack97 Visualizza il messaggio
    Oddio... Io ho una baseband diversa D:
    Per la gioia di @TheHack97...
    == PROPERTY INFO
    [23: 1:52] 1. download cable = USER
    [23: 1:52] 2. battery level = 100
    [23: 1:52] 3. download type =
    [23: 1:52] 4. download speed = 0
    [23: 1:52] 5. usb version = UHS
    [23: 1:52] 6. hardware revision = rev_10
    [23: 1:52] 7. download sw version =
    [23: 1:52] 8. device sw version = D85510l
    [23: 1:52] 9. secure device = S
    [23: 1:52] 10. laf sw version = 1.0
    [23: 1:52] 11. device factory version = LGD855AT-00-V10l-EUR-XX-SEP-29-2014-16G+0
    [23: 1:52] 12. device factory out version = LGD855AT-00-V10l-GLOBAL-COM-SEP-29-2014-16G+0
    [23: 1:52] 13. pid = BS03S140614002253
    [23: 1:52] 14. imei = 354153062419113
    [23: 1:52] 15. model name = LG-D855
    [23: 1:52] 16. device build type = U
    [23: 1:52] 17. chipset platform = msm8974
    [23: 1:52] 18. target_operator = GLOBAL
    [23: 1:52] 19. target_country = COM
    [23: 1:52] 20. ap_factory_reset_status = 6
    [23: 1:52] 21. cp_factory_reset_status = 0
    [23: 1:52] 22. isDownloadNotFinish = 0
    [23: 1:52] 23. qem = 0
    [23: 1:52] 24. cupss swfv = A1412000587-M1412000587-C1412005346-FFFFFFFFFFF-F
    [23: 1:52] 25. is one binary dual plan = 0
    [23: 1:52] 26. memroy size = 30777344
    [23: 1:52] 27. memory_id = SDW16G
    [23: 1:52] 28. bootloader_ver = MiniOS 3.0
    [23: 1:52] LAF : Bin_User_Mode
    [23: 1:52] isValidateSecureImage Device is a qfused.
    [23: 1:52] found sbl1 Partition for secure image check
    [23: 1:52] Secure Image
    [23: 1:52] found aboot Partition for secure image check
    [23: 1:52] found rpm Partition for secure image check
    [23: 1:52] found tz Partition for secure image check
    [23: 1:52] Secure Image Check Success
    [23: 1:52] * bootloader_ver = MiniOS 3.0
    Sto Guidando (cit. Dieguccio)
    Androidiano L'avatar di TheHack97
    Brescia
    LG G4 Leather Black (LG-H815)
    Ringraziato 81 volte in 67 Posts
    Scusa @DreamReaper ma ho eliminato il post dato che mi sono reso conto che il telefono aveva caricato qualcosa come un francobollo illeggibile... Se riesco riposto.
    Scusa ma in questo momento da quel LOG non riesco a trarre nulla di interessante... Un aiutino?
    PS: occhio all'IMEI
    Rieccola:
    Ultima modifica di TheHack97; 12-10-14 alle 23:16
  4. #1923
    PS: occhio all'IMEI
    Rieccola:
    Puoi evincere che la Rom è una GLOBAL che poi viene in qualche modo "adattata" al telefono. Quindi anche baseband e ammenicoli vari variano a seconda del dispositivo che hai
  5. #1924
    Brescia
    [quote name="TheHack97" post=6187620]Scusa @DreamReaper ma ho eliminato il post dato che mi sono reso conto che il telefono aveva caricato qualcosa come un francobollo illeggibile... Se riesco riposto.
    PS: occhio all'IMEI
    Rieccola:
    Puoi evincere che la Rom è una GLOBAL che poi viene in qualche modo "adattata" al telefono. Quindi anche baseband e ammenicoli vari variano a seconda del dispositivo che hai[/QUOTE]
    Quella particolarità l'avevo notata già nell'hidden dialer, tra l'altro.
    Comunque resta il fatto che le rom asiatiche sui nostri terminali non si adattano restando GLOBAL...
    EDIT: Io come v10L ho installato la ROM relativa al mio IMEI, svizzera da 32GB
    Ultima modifica di TheHack97; 12-10-14 alle 23:36
  6. #1925
    Senior Droid L'avatar di Giandrox
    Ringraziato 128 volte in 104 Posts
    Quote Originariamente inviato da Pisolo911 Visualizza il messaggio
    E con questo chiudo v10L.
    Strano, perché il server a me dice il contrario...
  7. #1926
    Aug 2014
    Pomezia
    LG G3 D855 32Gb
    Ringraziato 194 volte in 165 Posts
    Sulla 10L c'è ancora il bug del risparmio energetico che non regola la luminosità al valore selezionato in caso sia attiva la funzione luminosità automatica... ma hanno risolto qualcosa con questa 10L?
    LG G3 D855 32Gb - FW 20H
  8. #1927
    Androidiano L'avatar di Piterino78
    Nov 2013
    iPhone iphone4 s4 n5 g3
    Quote Originariamente inviato da Markbass91 Visualizza il messaggio
    Ma a me questa già funzionava!!
    Comunque per tutti quelli che hanno problemi con voice mate, ho rifatto un hard reset e si è sistemato
  9. #1928
    Aug 2014
    Pomezia
    LG G3 D855 32Gb
    Quote Originariamente inviato da Piterino78 Visualizza il messaggio
    Fai questa prova:
    1) imposta la luminosità a 50% o più e attiva la luminosità automatica
    2) imposta la luminosità col risparmio energetico a 30% o meno, come vuoi tu
    3) durante l'uso, spegni almeno una volta il telefono
    Vedrai che se hai spento almeno una volta il telefono, quando attiverai il risparmio energetico la luminosità non si abbassera al valore che volevi ma rimarrà al valore precedente. Fammi sapere se ti si presenta.
  10. #1929
    Androidiano VIP L'avatar di newpancio
    Redmi Note 3 Pro Kenzo
    Ringraziato 350 volte in 314 Posts
    premetto che io non uso mai il risparmio energetico .. ma ho fatto la prova ....
    facendo la prova che hai chiesto, a me la memorizzazione funziona (non sono però arrivato al minimo di batteria impostata).
    ... ma quindi, il tuo è un problema di semplice memorizzazione, indipendentemente dal fatto di esserci arrivato al minimo di batteria, o no ?
    p.s: invece a voi il meteo sulla schermata di blocco funziona ora (no modding) ??????
    Ultima modifica di newpancio; 13-10-14 alle 08:04
  11. #1930
    Androidiano L'avatar di simone1971
    Monteriggioni
    Samciuck Galaxy Note 4
    Ringraziato 23 volte in 16 Posts
    a me pc suite continua a segnalare la 10k come ultima versione disponibile...
