Visualizza i risultati del sondaggio: Quanto hai trovato utile la guida? Desideri che continuo?
Chi ha votato
45. Non puoi votare questo sondaggio
  • Scarsa, basta a scrivere guide e tweak
    0 0%
  • sufficente, se ti va e hai voglia potresti continuare a scrivere info
    1 2.22%
  • buona, scrivi più spesso info
    12 26.67%
  • OTTIMA!!! Continua spesso a informarci, vai alla grande!
    32 71.11%
Pagina 19 di 27 primaprima ... 91718192021 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 270
Guida all'uso per m2 note (e meizu in generale)
  1. #181
    Vergato
    Xiaomi Redmi Note 4
    Ringraziato 80 volte in 71 Posts
    E' uscita la 4.5.4I.
    Ecco il change log
    Highlight:
    This software update including enhancements and improvements for your device.
    Changelog:
    System
    Optimized the system apps' launching time.
    Settings
    Fixed the issue of incorrect consumed battery percentage in certain scenarios.
    Screen lock
    Fixed the issue that the system directly enters the master mode when immediately press Home button after the screen automatically turns off in Guest mode.
    Phone
    Optimized the noise processing for calls.
    Optimized the wakeup speed upon incoming calls.
    Fixed the issue of unstable voice volume heard over the receiver during calls.
    Fixed the occasional white screens occurred after the SIM card is hot plugged in.
    Fixed the issue of lapped incoming call screens when the mobile phone receives another incoming call during a call.
    Video
    Fixed the issue that Flac audio code is played without any sound.
    Camera
    Optimizing the slow video launching.
    Bluetooth
    Fixed the issue that the music played over the Bluetooth headset is stopped after the WeChat voice message is played.
    Third-party compatibility
    Fixed the issue of system crash when you touch the search button after the Titanium backup is completed.
    Tips:
    Downloading via mobile networks may incur additional charges. If possible, please download via Wi-Fi network.
    To avoid loss of data & if required, please perform Flyme or relevant backups before upgrading.
    To avoid bricking the phone, do not turn off or reboot the device while upgrading.
    Ultima modifica di arma1958; 29-09-15 alle 10:04
    May 2015
    Ciao a tutti, ogni volta che spengo il telefono e lo riaccendo scompaiono tutte le cartelle che avevo creato e devo rimettere i vari account sulle applicazioni(dropbox,box...etc) a voi succede o c'é qualche impostazione che mi sfugge? Grazie in anticipo
    Inviato dal mio m2 note usando Androidiani App
  4. #183
    Nov 2013
    Ringraziato 30 volte in 30 Posts
    Salve a tutti, nel menu non riesco a trovare la funzione per attivare la cover flip, sto uscendo pazzo. grazie.
  5. #184
    Apr 2014
    ma la sveglia continua a non funzionare a nessuno di coloro che hanno la versiona a??
  6. #185
    Jul 2015
    Ringraziato 213 volte in 121 Posts
    Quote Originariamente inviato da d146 Visualizza il messaggio
    a me funziona ...
  7. #186
    Apr 2014
    quale versione hai?Perchè praticamente non funziona a nessuno,anche se io sto un po arretrato visto che sto alla 4.5.2a
  8. #187
    Jul 2015
    Bhe essendo il papà dell'Italian Package non posso che avere la 4.5.4a ITA 1.6 ... e credo che a questo punto sei l'unico a cui ancora non funziona rimasto indietro di ben 2 aggiornamenti ....
  9. #188
    Apr 2014
    urca,due aggiornamenti?Ora mi attivo subito.
    Complimenti a te per aver fatto il lavoro.
    Mi linkeresti dove posso utilizzare anche io la versione internazionale?
  10. #189
    Jul 2015
    GUIDE DA SEGUIRE A TUA SCELTA
    - https://www.androidiani.com/forum/me...nazionale.html
    - https://www.androidiani.com/forum/me...n-package.html
  11. #190
    Apr 2014
    grazie mille,gentilissimo
