Magari sei in gamba nel sw ma in italiano zoppichi un poprostituirsi vuol dire altra cosa.
Sono emigrato in altro forum dove ho qualche amico. Il link a mega l'ho messo LI
Serenità e bellezza vanno cercate nelle piccole cose (kRel)
smartphone: invece di semplificare la vita la complica, invece di far risparmiare tempo ce ne fa perdere tanto
Spendere tanto è l'unico svantaggio, spendere poco comporta problemi e disagi. Spendere troppo poco equivale a perdita certa
Janobifronte (30-04-14)
vn800art (30-04-14)
Ho letto i change log, ma non ho letto del autoresolution, e dell' overlay.
codice:http://minix.com.hk/firmware/NEO_X7_20140429_010.zip MD5 checksum: 3d9d76bb9858211ba82b726a355e8a0a Update instruction (same as pre-010 and pre-010b): 1.) Download the above NEO_X7_20140429_010.zip file; 2.) Rename the file to "update.zip"; 3.) Put the file to the root directory (Also called "Internal Flash"); 4.) System will prompt asking for confirmation to update, choose Install; 5.) System will reboot itself and complete the rests of the process; 6.) Upon successful update, system will boot into the Launcher selection screen; 7.) Remove the update file when system prompt and ask you, or remove it manually; Change log (from 009): 1.) ROM built based on user mode 2.) Optimized HDMI parameters (NOTE: same as pre-010b) 3.) Fixed automatic shut-down bug 4.) Wifi is ON by default 5.) Screen scale preset to 100% by default 6.) System bar is hidden by default 7.) Enhanced Ethernet performance 8.) Fixed OTG bug 9.) Raised VCCIO voltage to improve system stability 10.) Update media library 11.) Fixed Wifi display app. bug (NOTE: this app. does not support SAMSUNG & SONY devices) ___ 12.) Fixed grey bar bug of stock video player (bug of pre-010b) 13.) AirPin software updated to V2.3.5 (supports Apple iOS screen mirroring, now the NEO completely replaces the Apple TV) 14.) New MINIX Metro launcher preloaded Regards, Team MINIX.
Attendero' prima di aggiornare
Ultima modifica di emerson120; 30-04-14 alle 20:51
per non combinare guai volevo un informazione,ho installato questo fw Minix X7 Android 4.4.2 KitKat, per installare il 010.zip (che ho gia scaricato) posso installarlo direttamente o prima devo mettere il fw originale? grazie.
pensionato (30-04-14)
no, e' il formato che usano per gli ota - permette di mantenere le impostazioni senza dover riconfigurare ed installare tutto ma per farlo non formatta tutto e reinstalla da zero, si limita ad aggiornare i file cambiati rispetto alla base - quindi necessita che la base sia esattamente quella prevista altrimenti succede un macello
