Ecco la procedura : Camera autofocus doesn't work - Or camera doesn't work at all
[Don't unscrew] Frist thing you should try is remove the back cover and give a presure in the right side of your camera with your finger.. this is the place the connector is located.. and it may gets unclipped and loose the connection after a small drop or something. After that Reboot the phone.
[unscrew back] If this presure on the right doesn't fix it, then you have to unscrew the phone.. take off the camera and give it some small hits and punches.. place back the camera and see if it works.. this is due the autofocus motor got stuck.
Mobiuncleo utilizzato per alzare i volumi.Forse devo root e magari con rom nuova miglioro device.
Tutto sommato nn mi posso lamentare.
LinkBack URL
About LinkBacks
