Pagina 14 di 34 primaprima ... 4121314151624 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 333
ZP810HD Modding Thread
  1. #131
    ZP810
    Vi riporto quanto trovato:
    [vdm rom] rom jb 4.2.2 update fixed - 13.6.2013
    [VDM ROM] ROM JB 4.2.2 UPDATE FIXED - 13.6.2013
    Google translated from Vietnamese to English
    JB'S VERSION 4.2.2 BUG FIX HAS DONE. FIX THE INFORMATION ROM:
    FIX "press"
    FIX CAMERA CENTER HONG 99%, PHOTOGRAPHS USED APP DEFAULT, SAVE FROM photos 1MB-3MB. BUT SMALL PLATE CAPACITY BUT SHOOTING GALLERY very sharp, ZOOM KO BE photograph mother's maiden name as you advance. QUALITY OF THE VIDEO IN YOUR CHOICE "NET", while filming WILL HD1088 resolution
    APPLICATION FOR STILL HEAR MUSIC APP DEFAULT, VIPERFX RESEARCH HAS MORE CORRECT DATA AVAILABLE, THE ROM YOU UP JUST ENJOYING THE PLUG PHONE.
    OPTIMAL build.prop, 3G STANDARD FIXED FAST.
    CHANGE AS NEW SYSTEM INTERFACE OF THE HDBK 28.5
    THE MESSAGE OF USE APP 4.1.2 CHANGE AS nicer interface SGS4
    LOT CHANGE SYSTEM FOR THE ROM smoothly: "Behold smoother smoother." "LIKE DAUGHTER soft 18"
    Children shifted slightly lockscreen FIX IS NOT TO BE.
    TIP USE INSTRUCTIONS:
    The "Turn off smart screen" available to customize the configuration and then, after finishing rom, open the smart screen off, activate selected
    In settings - Security: - Built-selected "unknown origin"; - Uncheck "verify application"
    In settings - Date & time: - Built-select "All times automatically"; - Select the date format "area (....)"
    Installing wallpaper is the galaxy s4: I have this beautiful tune parameters available.
    Weather widget has changed the bulbs look better, too bad the new version. ^ ^
    1 wave 2 sim: sim to change color settings for black waves hidden
    You do vina + 3G mobile users: in settings - more ... - Mobile networks - access point names - select sim - APN change is "m-i090", and the password: "mms". 3G speed is very fast. Viettel I do not know do not use
    Qui l'ho scaricata ma non ancora installata:
    //pan.baidu.com/share/link?shareid=3736061404&uk=1664554949&third=15
    tivoli (Rm)
    NOTE 3 Neo LG G2 16 gb
    ciao sono riuscito ad inserire imei della sim 1 faccio lo stesso procedimento sulla sim 2 ma niente non carica imei
  4. #133
    Salve, grazie per le info utilissime che fornite, volevo solo chidervi una cosa mi spiegate i passi per aggiornare la baseband. io ho ancora la verisione 4.1.2 la baseband moly.wr8.w1248.md.wg.mp.v2.p1 2013/02/02/ 23.29, ho già applicato il fix per il 3g e cambiato in gsm/wcdma (auto), ed effettuato il root. siccome ho riscontrato che passa da h a h+ ecc in modo anomalo a mai stabile pesavo di poter risolvere il problema. Altra cosa se dovesse andare male potrei ritornare al baseband precedente? grazie a tutti
  5. #134
    tivoli (Rm)
    Aiutofatto tutto ma non riesco a ripristinare imei della sim 2 ho seguito il procedimento manuale su youtube ma niente potete aiutarmi a risolvere il problema Grazie
    Quote Originariamente inviato da Iori82 Visualizza il messaggio
    EUREKA!!!!
    Funziona Finalmente!!!
    snip...
    Ultima modifica di PaoloW8; 21-06-13 alle 22:51 - Motivo: ridotto quote
  6. #135
    ZP810
    Quote Originariamente inviato da max1977 Visualizza il messaggio
    Se hai la 4.1.2 consiglio di non installare la baseband. Io l'ho fatto 2 volte e non ptendeva piú alcun segnale
    Ultima modifica di LuigiP77; 19-06-13 alle 23:02
  7. #136
    ZP810
    Ciao Deslok
    Sul video ho riscontrato un errore. per la sim 2 devi selezionare AT+EGMR=1,10, ""
  8. Il seguente Utente ha ringraziato LuigiP77 per il post:
    deslok (19-06-13)
  9. #137
    tivoli (Rm)
    grazie luigiP77 sei stato gentilissimo ciao
  10. #138
    Honor 8
    Ringraziato 38 volte in 32 Posts
    si confermo l errore del video cmq io sto aspettando una bella rom..abbiamo un grande cell ma un os ancora mediocre..uff.Non sfrutta niente. e ho visto rom su mtk 6577 eccezionali ..mah
  11. #139
    Palermo
    Zopo ZP 810 HD
    Al momento per me la migliore ROM è la "4.2.1 DzhYn Custom 4 'Glass Mod'", la consiglio vivamente!!
    Di default c'è il tema next launcher, l'unica cosa che non mi piace e l'ho tolto.
    L'unico problema è che essendo una versione "glass" del playstore e google now, non permette l'aggiornamento del google play services e di conseguenza non posso nemmeno installare app come Google+ e Hangouts.
    Qualcuno sa dirmi come posso fare? Aiuto!
  12. #140
    HollyDroid
    A chi può interessare è uscita la nuova Hkphone del 08-07-2013
    link: https://docs.google.com/file/d/0BxNL...cTA/edit?pli=1
  13. Il seguente Utente ha ringraziato enzo27 per il post:
    ninfole (10-07-13)
