Utente della settimana: 9mm con ben 4 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 18 Thanks ricevuti nell'ultimo mese
Pagina 49 di 79 primaprima ... 39474849505159 ... ultimoultimo
Visualizzazione dei risultati da 481 a 490 su 786
Tablet Altroconsumo 8" (2016/2017) - RK312x 1.3 Ghz - 1GB RAM - 8GB Flash (Modding)
  1. #481
    Mar 2017
    Quote Originariamente inviato da Carontes Visualizza il messaggio
    You should have a Hynix v3.1 version (take a look for more informations), and for that version there isn't yet a "custom ROM". I'm trying to build it but I don't have the same tablet model and also I'm a little bit busy. For now you could only flash the TWRP recovery but it only works with a mouse using the otg since touch screen doesn't work on recovery
    Many thanks for the reply, yes I have a OTG so should be pretty fine, can I ask if the nandroid backup works for restore and backup in this version of trwp?
    If you want I can disponibilize you my dump rom to check...
    Ultima modifica di hertzpt; 26-03-17 alle 00:21
    Apr 2011
    Bologna
    Huawei Ascend Y300
    Ringraziato 95 volte in 36 Posts
    Quote Originariamente inviato da hertzpt Visualizza il messaggio
    The backup and restore should work fine according to users that tried them (I've never tried them to be honest). I already have a dump thanks, but if I need another dump I'll definitely ask to you
  4. #483
    Dec 2015
    From the screenshots you posted before your tablet looks like my version (hynix 3.1).
    Further check by reading your Settiing -> Info and compare with mine
    Android version: 5.1.1
    Kernel version:
    3.10.0
    xwp@incar #819
    Sat Dec 3 14:17:08 CST 2016
    Build number:
    rk312x-eng 5.1.1 LMY47V eng.zhangxy.20161209.183742 test-keys
    I can confirm that TRWP backup & restore works fine on my tablet. If you are interested on rooting, download and flash my HynixV4_root_twrp_ROM dump.rar
  5. #484
    Mar 2017
    Ok I will test, if you need as you said let me know.
    Quote Originariamente inviato da baibai Visualizza il messaggio
    Yes it's the same! Your dump have only Root? No more modifications or apps?
  6. #485
    Dec 2015
    Root only + Terminal Emulator app
  7. Il seguente Utente ha ringraziato baibai per il post:
    hertzpt (26-03-17)
  8. #486
    Androidiano L'avatar di tidus_86
    Alghero
    Galaxy S23
    Ringraziato 24 volte in 16 Posts
    E' rischioso per la batteria caricare il tablet utilizzando un carica batteria per smartphone (Galaxy S3)? Cosa può succedere, a parte caricare più lentamente?
  9. #487
    Mar 2017
    Do you have issues with your wifi? And is your tablet very slow in apps like youtube?
    Hai problemi con il wi-fi? E il vostro tablet è molto lento in applicazioni come YouTube?
    Ultima modifica di hertzpt; 26-03-17 alle 19:28
  10. #488
    Senior Droid L'avatar di i-green
    Samsung A7 (2018)
    Ringraziato 33 volte in 26 Posts
    Alla fine ce l'ho fatta e sono riuscito a far funzionare la TWRP in tutte le sue parti, forse l'unica cosa che potrebbe non funzionare è l'USB OTG, ma mi sembra irrilevante visto che funziona sia l'USB che la scheda SD. Ho inoltre aggiornato la ROM che avevo fatto con vari fix. Se volete provarla fatemi sapere poi cosa ne pensate e se ci sono miglioramenti che potrebbero essere fatti. I file zip delle due ROM contengono già al loro interno l'immagine per la recovery TWRP (recovery) ma anche per la recovery stock (recovery_stock).
    Rom Micron v.2: qui
    Rom Hynix v.2: qui
    Solo recovery TWRP 3.1.0-0: qui
    Novità v.2:
    • Aggiunto supporto ad init.d. Se volete aggiungere file alla cartella init.d (che presenta già dei file impostati da me per automatizzare alcune impostazioni) potete modificare il file "script.sh" presente in "system/bin" anche per i permessi.
    • Rom rootata e già installata l'app SuperSU.
    • Adesso l'equalizzatore AudioFX funziona veramente.
    • Risolto il problema che non permetteva di leggere le schede SD al tablet (errore mio, scusate).
    • Aggiunti gli stessi parametri che utilizza l'applicazione L-speed. Non c'è bisogno di installare l'applicazione, ma se non ne siete convinti potete sempre scaricarla.
    • Aggiunti altri parametri utili per velocità, stabilità e batteria.
    Per installare la ROM e la recovery bisogna utilizzare AndroidTool (già presente nei due file zip delle ROM)
    Ho flashato la Micron V2, tutto è filato liscio (almeno in apparenza) ma ... adesso non si accende più! Schermo nero, non entro nel bootloader e AndroidTool lo riconosce come ADB devices. Che posso fare?
    ________________________
    Update
    Adesso tramite i comandi adb sono riuscito a mandarlo in bootaloader e riprovo la procedura di flash .. vediamo. La formattazione va a buon fine ma se faccio RUN adesso si blocca su "Download image failed"
    Ultima modifica di i-green; 27-03-17 alle 15:41
  11. #489
    Dec 2015
    Main lacks of this model are wifi connection (i.e. sensibiliy, stability) & battery drain.
    Let's hope specialized app and sw customization could improve. Everybody with interesting info/experience are invited to share on this forum
    Ultima modifica di baibai; 27-03-17 alle 20:05
  12. Il seguente Utente ha ringraziato baibai per il post:
    hertzpt (27-03-17)
  13. #490
    Apr 2011
    Bologna
    Huawei Ascend Y300
    Quote Originariamente inviato da i-green Visualizza il messaggio
    Update
    Hai verificato che il tuo tablet sia Micron? La procedura di installazione va sempre a buon fine ma se il tuo tablet è Hynix è normale che ti compaia una schermata nera. Tramite l'altro thread verifica che versione del tablet hai. Se hai Hynix v.1 puoi flashare la mia versione altrimenti non flashare nulla. Se e quando riuscirò a fare una versione adatta anche ad Hynix v.2 e 3 ve lo dirò
