Pagina 22 di 200 primaprima ... 1220212223243272122 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 1997
[ROM][4.4] CyanogenMod 11 - S3 mini
  1. #211
    E' uscito un nuovo aggiornamento che dovrebbe risolvere tutti i problemi della fotocamera. Ho un problema con le GAPPS, ovvero i server del sito di Maclaw sono abbastanza ridotti male da non farmi completare mai il download del pacchetto Google Apps (4.4.x) full 20131126 -.- qualcuno sà dove posso trovare un link alternativo?
    RELEASE for S3 Mini
    CyanogenMod 11.0
    New release (20131229) of CM11.0 for S3 Mini is available!
    For flashing KitKat, we recommend you to install our TWRP recovery (available on Download page)!
    If you want to say thanks by donating us using PayPal, feel free ;-)
    Do full backup before installation and wipe data/cache (factory reset) after installation (only from stock ROM).
    If you’re updating from older CM10.1/10.2/11.0 version or migrating from Oliver’s CM, you don’t have to perform a wipe!
    You can get it on our DOWNLOAD page.
    Changelog:
    CM sources update
    stable release
    new RIL is stable now
    Camera app sources has been finally repaired and now Camera is being compiled again
    removed no needed codecs from OMX implementation
    boot should be even faster
    Odin package also updated
    Features
    2D/3D HW Acceleration
    audio (both speakers/headphones/microphone)
    GPS and A-GPS – fast fix getting
    Glonass navigation
    compass
    sensors
    Wi-fi
    Bluetooth 4.0 with LE support A2DP
    all native tethers (Wifi/BT/USB)
    Google Play
    CM11 functionallity
    CPU sleep mode
    MTP
    ADB
    no tearing
    tripple buffering
    YouTube HQ
    Wifi direct
    3.0.101 kernel
    external storage
    native 64GB+ sdcard support (exFAT)
    camera
    video playing
    SELinux (temporary disabled)
    BLN (backlight notifications) support
    offline charging
    auto EFS backup
    New BT/GPS/offline charging/sensors drivers – no longer buggy Samsung’s ones!
    built using Linaro toolchain
    no 1GHz bug
    also flashable via Odin
    Issues
    none
  4. #213
    Scusate la domanda, dopo vari tentativi finalmente sono riuscito a scaricare e mettere le GAPPS. Il pacchetto FULL ha delle applicazioni che onestamente non userò mai ma con Root Uninstaller mi dice che non le posso levare. Il programma ha ricevuto correttamente i permessi di Root, come posso fare?
    P.S nella ROM funziona tutto perfettamente per quello che ho provato in queste ore
  5. #214
    Androidiano L'avatar di sdylan
    Feb 2010
    Quote Originariamente inviato da andream8891 Visualizza il messaggio
    Non riesco a scaricarla, o meglio la scarico ma mi da sempre file corrotto...alternative ?
  6. #215
    Quote Originariamente inviato da sdylan Visualizza il messaggio
    Faceva lo stesso anche a me, provando più e più volte alla fine mi ha scaricato una versione non corrotta... certo che scaricare 250 mb ad una velocità media di 60/70 kb al secondo per 5-6 volte mi ha levato più tempo di tutta la procedura di flash -.-
  7. #216
    Feb 2010
    A me da 190 mb, come mai a te ne da 250 ?
  8. #217
    Si scusa io mi riferivo alle GAPPS tu alla ROM :P cmq ho avuto problemi con il download di entrambi... alla fine bisogna fare diversi tentativi e onestamente io con Chrome non sono mai riuscito a scaricare un file non corrotto dal sito di Maclaw quindi se lo usi ti consiglio di cambiare anche browser che danno meno problemi nel download
  9. #218
    Feb 2010
    Fatto, dopo 6 tentativi........
  10. #219
    Androidiano L'avatar di foost75
    galaxy S3 Mini i8190
    Ringraziato 2 volte in 1 Post
    Per informazione io utilizzo jdownloader per scaricare dal sito maclaw. Primo seguo il percorso per scaricare quello che mi serve, poi quando parte il timeout di 10 sec per il download copio il link che c'è nella barra di ricerca e lo copio manualmente in jdownloader. Lui mi dice se voglio controllare i file collegati a quel link e io acconsentì. Trova così circa 5 file... Cancello quelli che non mi servono e poi procedo al download. Se il server da problemi riparte lui con il download. Alla fine come sapete scompatta il file e quindi so che ha scaricato regolarmente il pacchetto. Elimino la cartella estratta e tengo il file. Zip. Ciao
  11. #220
    bologna
    sams gts5300/ xperia u/p7500
    Scusate domanda stupida, ho scaricato la maclawstudio-TWRP-2.6.3.0-KitKat.zip all'interno trovo il file recovery.img partendo da un terminale originale come la installo? ho letto qualche guida e mi sembra che tutte facciano riferimento a file .tar da caricare con odin.
    Mi è sicuramente sfuggito qualcosa ma cosa??
    Grazie e auguri a tutti di Buon Anno.
