Pagina 128 di 268 primaprima ... 2878118126127128129130138178228 ... ultimoultimo
Visualizzazione dei risultati da 1,271 a 1,280 su 2678
[ROM] [AOKP] Android Open Kang Project 4.0.4 - BUILD 36 - MIL 5
  1. #1271
    Androidiani Power User L'avatar di Tatuato
    Feb 2010
    Caserta
    Xiaomi Mi9; Mi A2
    Ringraziato 1,943 volte in 653 Posts
    Quote Originariamente inviato da mikyfootball Visualizza il messaggio
    uscita build 28..permette il cambio colore del lockscreen
    Inviato dal mio Galaxy Nexus usando Tapatalk
    Aspetta in che senso? Il colore di cosa? Del pulsante di sblocco?
    Io sto aspettando gli eventi del calendario nel lockscreen, appena li mettono io cambio
    edit: si ci sono
    Changelog build 28:
    Added lockscreen color changer
    Added 'traditional' toggle layout [where the toggles are on the very top] (Stevepear426) -- find in RC > Statusbar General > Layout
    Added AOSP lockscreen style (Whitehawkx)
    Added extra volume slider options (Stevepear426, tmoskowite on gummy)
    Added lockscreen calendar options (!!!) (sethyx)
    Removed any trackball support the ROM had, was only throwing errors, not properly implemented
    Improved brightness slider under toggles, doesn't jump anymore
    Improved brightness slider (when sliding your finger across the statusbar if enabled). MUCH more responsive now
    Added fast charge toggle for maguro/toro for kernels that support it (Zaphod-Beeble)
    Added ability to set custom lockscreen image for targets. Click picture in RC to set.
    Also increased size of custom lockscreen images to more match the normal icons
    Improved
    Including AppWidgetPicker to help organize widgets
    Added digital clock widget to desk clock
    battery bar should no longer disappear when in the navigation bar
    added the following devices: p999, p990, tf101, p5wifi,
    Ultima modifica di Tatuato; 21-03-12 alle 19:38
    Device: Xiaomi Mi9 - Mi A2
    Nothing to donate, just appreciate!
    Senior Droid L'avatar di iltommi
    Google Galaxy Nexus
    Ringraziato 65 volte in 60 Posts
    Quote Originariamente inviato da Tatuato Visualizza il messaggio
    edit: si ci sono
    Changelog build 28:
    Improved
    Notizie se sulla batteria sia avida come la mil4? Io sono ancora ancorato sulla 3 ma mi prude la recovery
    Sent from my Galaxy Nexus
  4. #1273
    Androidiano L'avatar di EnzoTekno
    Mar 2011
    Non è un problema reale, è solo un bug della recovery CWM ma il wipe te lo fa comunque.
    Per le gapps, hai scaricato le ultime come scritto nel troubleshooting il cui link è alla prima pagina della rom su xda?
    Installa prima la rom poi le gapps e poi riavvia, non dovresti avere problemi avendo preventivamente effettuato un wipe di tutto.
    Adesso sto scaricando quelle dal link di xda dal nome nn sono le ultime sono le 20120304 spero di risolvere ;
    Inviato dal mio iPhone usando Tapatalk
    Modello :Samsung Galaxy S3
    ROM: FoxHound Rising v1.6
    Kernel: Phenomenal 4.0 Extreme
  5. #1274
    Samsung Galaxy Nexus
    Quote Originariamente inviato da EnzoTekno Visualizza il messaggio
    Build 28 queste sono le ultime però anche io ho notato che all'intenro mancano alcune app....bu...
    ROM : Xylon 4.2.1
    KERNEL : kernel Rom
    BASEBAND : non mi ricordo XD
  6. #1275
    Mar 2011
    Quote Originariamente inviato da -StYlEr- Visualizza il messaggio
    Cmq negli zip scaricati che stanno sul link ufficiale le app mancanti non ci sono nella cartella system/app.... secondo me si dovrebbe trovare uno zip di gapps piu vecchio....
  7. #1276
    Ringraziato 10 volte in 8 Posts
    Ma come va questa build 28??...
    Io ho la milestone 4....volevo provarla...però prima mi piacerebbe sentire qualche impressione di chi l'ha già provata....!!
  8. #1277
    Feb 2010
    Caserta
    Xiaomi Mi9; Mi A2
    Quote Originariamente inviato da iltommi Visualizza il messaggio
    Usando franco.kernel M2 non è per niente avida credimi, anche la M4.
    Le ultime gapps sono queste: 20120317
  9. #1278
    Mar 2011
    Cmq io con la build 28 e il franco mile2 mi ci sto trovando un'amore con un uso normale internet fisso e telefonate a manetta ho coperto 11 ore con il 65 % di batteria... La differenza dal vecchio franco è abissale. Unica pecca anche se irrilevante sono le suonerie stock che pare siamo troncate alla fine...
  10. #1279
    Ciao a tutti gli amici del forum. Attualmente monto la mil4, purtroppo ho un problema riguardo la galleria fotografica. Praticamente quando la apro si richiude dopo qualche secondo e mi ritorna al desktop. Come posso risolvere? Grazie.
  11. #1280
    Quote Originariamente inviato da tornadofca
    Io avevo lo stesso problema pero lo faceva solo con una cartella in particolare... A te con tutte le cartelle presenti in galleria?
    ROM : Xylon 4.2.1
    KERNEL : kernel Rom
