Pagina 5 di 8 primaprima ... 34567 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 79
[ROM]CyberGR-MOD | tweaks++ | mods++
  1. #41
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    R: [ROM]CyberGR-MOD | tweaks++ | mods++
    Quote Originariamente inviato da Cybergr Visualizza il messaggio
    Update it`s coming in the next hours..Currently uploading.
    Here is a change log for CyberGR|MOD Ver.2 Nemesis 20130308 Build:
    - Merged with Latest AOSP 4.2.2 sources.
    - Updated AK Purity Kernel to ver.30
    - Fixed LockScreen Target alignment.
    - Chronus Clock can be fully displayed even at stock 320DPI.
    - PIE improvements and attempt to fix invisible PIE problem after unlocking screen.
    - Added Disable FullScreen Keyboard when your typing in landscape mode option under ROM Tools.
    - Added Low Battery Warning, Lockscreen See through and Volume Key Cusror options Control under ROM Tools.
    - Softkeys and Screen Security options removed from ROM Tools.
    - Fixed a problem with Face Unlock.
    - Fixed Contact share problem.
    - Fixed Profile Toggle.
    - Updated Toggle Icons.
    - Added QuickRecord Toggle.
    - Fixed LockScreen NavBar Trasparency.
    - Updated CyberGR|MOD GAPPS.
    - Removed Metrostation Icon Pack app.
    - Fixed some init.d and build.prop tweaks.
    - Updated SuperSU, Talkback, Google Music.
    - Automatically lock changes will stick but they will display 5 secs time.
    Tapatalkeggiato
    CyberGR|MOD Ver.2 It`s finally up on GOO.im + new 4.2.2 CyberGR|MOD GAPPS.
    OP has been updated with Latest ROM and GAPPS links.
    Screen shots and a complete list of Change Log (see 3rd post on the OP) has been added too.
    Enjoy!!
    Tapatalkeggiato
    Ultima modifica di Pelide; 08-03-13 alle 18:50
    Jul 2010
    Galaxy s4 - Galaxy Nexus
    ma per fare l'upgrade all'ultima versione basta solo wipe cache, dalvik.
    flash rom e flash gapps giusto?
  4. #43
    Senior Droid L'avatar di Bhelzebu
    Jun 2010
    Ringraziato 96 volte in 85 Posts
    è un problema se la flasho partendo da una 4.1.2?
  5. #44
    Rovigo
    Nexus 4
    Ringraziato 73 volte in 59 Posts
    Aggiornata la prima pagina coi link al download della rom e delle gapps..
    Quote Originariamente inviato da Bhelzebu Visualizza il messaggio
    sarebbe meglio che prima aggiorni alla stock 4.2.2 così ti aggiorna la baseband in automatico e non hai problemi per quanto riguarda la cartella \0
  6. #45
    Androidiano L'avatar di dellabest
    Ringraziato 21 volte in 19 Posts
    Quote Originariamente inviato da gulp Visualizza il messaggio
    Mi associo anche io alla richiesta...
  7. #46
    Giangiui
    Ma le versioni 4.2.2 sono nightly o stabili?
  8. #47
    Jul 2010
    Quote Originariamente inviato da dellabest Visualizza il messaggio
    Dovrebbe bastare, la versione del sistema rimane la solita.
    Nel caso notaste problemi farete una bella pulizia
    Quote Originariamente inviato da Lui92 Visualizza il messaggio
    Stabili
    Tapatalkeggiato
  9. Il seguente Utente ha ringraziato Pelide per il post:
  10. #48
    Androidiano L'avatar di astro1980
    Curioso di provarla, oggi la monto. Qualcuno l'ha raffrontata con la vanir, c'è molta differenza in termini di reattività?
  11. #49
    Rovigo
    Nexus 4
    Quote Originariamente inviato da astro1980 Visualizza il messaggio
    Io le ho provate entrambe..sono similari in termini di prestazioni..
  12. #50
    solo a me capitano riavvi con questa rom, il kernel è quello di default.. quasi un riavvio al giorno
    ora sto provando a piallare tutto e metto la v. 2
    speriamo si risolva tutto perchè mi sto trovando veramente bene, fluida, veloce e buona autonomia batteria
