Pagina 23 di 25 primaprima ... 132122232425 ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 242
[ROM][JB 4.3][JWR66V] Cataclysm ROM
  1. #221
    Ringraziato 88 volte in 14 Posts
  2. Il seguente Utente ha ringraziato atl4ntis per il post:
    drum89 (21-08-13)
    Androidiano L'avatar di Riff95
    MANTOVA
    LG G2 16gb
    Ragazzi è uscita una nuova versione!
    Changelog:
    Aug 23, 2013: Added ZH translation. (wasdf)
    Aug 22, 2013: Updated rom sources to android-4.3_r1.1 JWR66Y.
    Aug 21, 2013: SoftkeysFadeMod: temporarily disable on ringing call.
    Aug 21, 2013: Added VI translation. (dunghnguyen)
    Aug 20, 2013: Added PT translation. (tiaoAlvino)
    Aug 20, 2013: Added SK translation. (matesc)
    Aug 20, 2013: Added CS translation. (matesc)
    Aug 20, 2013: If longpress home to app drawer is enabled Gnow ring won't popup, you can still swipe up tho.
    Aug 20, 2013: Added ES translation. (nachordez)
    Aug 19, 2013: Added DE translation. (matesc)
    Aug 19, 2013: Added FI translation. (TToivanen)
    Aug 19, 2013: Added NL translation. (kriss1981)
    Aug 18, 2013: FakeCall: added scheduler (time/date).
    Aug 17, 2013: QuickToggles: added Volume tile.
    Aug 16, 2013: VolumeWake won't wake the screen when music is playing, it will with both volUp volDown pressed.
    Aug 16, 2013: Clear All Recents became smarter and won't kill the task from which is invoked.
    Aug 15, 2013: QuickToggles: added optional 4 columns portrait layout.
    Aug 15, 2013: Added RU translation. (gaich)
    Core Gapps are still included but removed the ones you can easily download from Play Store if you want.
    Books - Calendar - Currents - Gmail - Ears - Earth - Hangouts - Keep - Google Keyboard - Magazines - Movies - Maps - Music - G+ - Street - talkback - Google Now - Wallet - YouTube.
    -> DOWNLOAD
    Ciao
  5. I seguenti 3 Utenti hanno ringraziato Riff95 per il post:
    fedelamb (23-08-13),Fuorezza (23-08-13),morfances (23-08-13)
  6. #223
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da Riff95 Visualizza il messaggio
    -> DOWNLOAD
    Ciao
    grazie aggiorno prima pagina xD
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  7. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    Fuorezza (23-08-13),Riff95 (23-08-13)
  8. #224
    Galaxy Nexus
    Sempre fantastica questa rom! Con questa ultima versione con le gapps ridotte e senza hangouts ho potuto reinstallare gtalk solo copiando gtalk.apk in system/app!!
  9. #225
    Androidiano L'avatar di FoxLine
    Asus ZenFone 2 ZE551ML
    Anche in quest'ultima versione le gapps sono sempre incluse?
    Rom: Android 6.0.1 Marshmallow Stock
    Kernel: Stock
    Launcher: ZenUI
    Recovery: Stock
  10. #226
    Galaxy Nexus
    si.......ma ridotte!
  11. #227
    Androidiano L'avatar di crashTPS
    Samsung Galaxy S8
    Ragazzi, stavo provando a mettere l'ultima versione...quella del 23 Agosto, insieme al Fancy Kernel
    Ho flashato il tutto e all'avvio mi esce in continuazione la schermata " il processo com.android.phone si è arrestato improvvisamente "
    Allora ho visto che poteva essere che avevo scaricato male l'ultima versione, ho fatto tutti i wipe necessari e ho riflashato il vecchio zip della Cataclysm insieme alla Cumulative, ma niente, mi da in continuazione lo stesso errore
    Cosa mi consigliate di fare?
  12. #228
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Quote Originariamente inviato da crashTPS Visualizza il messaggio
    Prova così , da redovery twrp : wipe davlik + cache , wipe system , flash rom + gapps.
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
  13. #229
    Samsung Galaxy S8
    Quote Originariamente inviato da dadenet Visualizza il messaggio
    Le gapps sono incluse...o mi sto sbagliando? :o
    Comunque ho risolto proprio così, ma flashando solo la prima versione che avevo
    Le altre non girano
    Non ho riflashato più neanche il Fancy
  14. #230
    GNexus, Nexus 5/6
    Le altre non girano
    Si esatto ! , puoi flasharlo il kernel se vuoi.
