Pagina 28 di 30 primaprima ... 182627282930 ultimoultimo
Visualizzazione dei risultati da 271 a 280 su 298
Nexus Root Toolkit By WugFresh
  1. #271
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Disponibile nuova versione 1.7.9 :
    What’s new in Nexus Root Toolkit 1.7.9: December 4th, 2013
    · Added “No Wipe Mode” to the toolkits flash stock options to allow for flashing the factory packs without wiping userdata and cache.
    · To make this new ‘No Wipe Mode’ function properly the flashstock.bat was revised.
    · Code revisions were also made to allow the new ‘No Wipe Mode’ feature to work with ‘Force Flash Mode’.
    · Revised the toolkits ‘first run’ behavior to autodownload the latest masterlist first – before the user is presented with the device/build selection window.
    · To accommodate end-users from countries that were blocking Pastebin; the masterlist files are now stored and read in from my Github Gist account instead.
    · The ‘OEM Lock’ script was modified to perform a different procedure for Nexus5; more specifically – now it temporarily boots TWRP and autoflashes a zip made by XDA contributor osm0sis to relock the bootloader and reset the tamper flag.
    · Fixed the ‘restore nandroid’ buttons activity which was mistakenly disabled in v1.7.8 from an indirect change.
    · Updated the code for the Uninstall_NRT.exe to require admin rights to accommodate for Win8′s requirements for modifying/deleting any ‘Program Files’ sub-directories.
    · Corrected some message/info box typo’s.
    · Some other small code revisions, fixes and optimizations.
    p.s. per aggiornare basta lanciare il vs. toolkit installato sul pc.
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da dadenet Visualizza il messaggio
    ti avevo gia fregato xd
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  4. #273
    GNexus, Nexus 5/6
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Hai ragione caro ! faccio venia !
  5. #274
    Ciao Ragazzi questo è il mio problema : il cell funzionava perfettamente quando ad un tratto si è spento,successivamente riaccendendolo non mi va più su Android ma in modalità download.Allora ho provato tramite Odin a flashare la 4.3 solo che quando accedo al sistema operativo mi compare in basso a destra la scritta " Safe mode " se spengo\riaccendo mi ritrovo in download mode.Ho provato a flashare sempre tramite Odin la 4.2 e la 4.1 ma ottengo sempre lo stesso risultato. In passato avevo flashato la 4.3 tramite comandi fastboot solo che adesso quando accendo il cell in fastboot mode il pc non me lo riconosce. Adesso ho provato il Nexus Root Toolkit By WugFresh, installo driver seguendo la procedura e va tutto bene ma quando eseguo il " Full drivers test " il cell si riavvia in fastboot mode ed il pc non me lo riconosce più. L'unico modo per farlo rilevare è tramite Odin. Cosa posso fare ? Grazie in anticipo
    Versione toolkit : 1.7.9
    Versione Android : 4.3 ( prima, adesso credo niente visto che si trova in download mode )
    Sistema Operativo PC : Windows 8 64 bit
    Cell : Galaxy Nexus 16 gb
    Queste sono le info che mi dà quando lo accendo :
    Board name : tuna Rev 9
    Board Rev : HSPA - 9
    Boot Type : USB MMC1
    Device Type : HS
    Build Date : Apr 24 2013
    Ultima modifica di Gas87; 09-12-13 alle 20:47
  6. #275
    Sep 2010
    ROMA
    Rimetti la factory Image con il toolkit
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #276
    Ho appena provato ma quando il toolkit mi riavvia il cell in fastboot mode non lo trova più " Fastboot device was not found "
    Adesso sono ribloccato in download mode , se voglio riaccedere ad android devo nuovamente flashare tramite Odin, cmq quando il cell è su android se vado su gestione dispositivi ( PC ) mi riconosce il cell con i driver ADB .
    Come drivers nello step 2 ho usato i Driver Solution #1 Universal Drivers
    Ultima modifica di Gas87; 09-12-13 alle 21:26 - Motivo: Ho aggiunto informazioni
  8. #277
    Androidiano VIP L'avatar di pablito71
    Feb 2011
    fossacesia
    Ringraziato 123 volte in 105 Posts
    avevo una versione vecchia del toolkit,appna aperto mi ha fatto l'aggiornamento.
    ma con il telefono collegato quando avvio il programma mi escono questi errori
    2013-12-11_15-46-02.jpg2013-12-11_15-46-39.jpg2013-12-11_15-47-26.jpg2013-12-11_15-48-23.jpg
    felice possesore di nexus one-nexus 7
    non ringraziarmi se ti sono di aiuto ma premi thanks
  9. #278
    Sep 2010
    ROMA
    Quote Originariamente inviato da pablito71 Visualizza il messaggio
    devi premere 'change' e mettere il modello corretto del tuo dispositivo
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  10. #279
    Feb 2011
    fossacesia
    scusami dei primi tre screen me ne devo fregare?ok clicco change nel toolkit ma mi sembra quella la mia versione nexus5 con ancora 4.4 con root e da poco anche con recovery twrp.
    cosa devo mettere li? vorrei usarlo per aggiornare alla 4.4.2,quale è la voce che lo fa?
  11. #280
    Sep 2010
    ROMA
    veramente di ho consigliato di premere 'change' perche qui siamo nella sezione del gnex (galaxy nexus)
    per fare l'aggiornamento a 4.4.2 del nexus 5 ..c'è un thd apposito
    qui sei OT
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. Il seguente Utente ha ringraziato morfances per il post:
    pablito71 (11-12-13)
