Pagina 5 di 35 primaprima ... 3456715 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 350
[ROM][KK - 4.4.x][HALO][PIE][Wifi Display]CM-REMIX-Burst-Kernel-KANG
  1. #41
    Senior Droid L'avatar di vismo
    LG G3
    Ringraziato 166 volte in 146 Posts
    Salve gente...ho installato questa rom da poche ore...prime impressioni molto molto positive...vediamo come si comporta a lungo termine...vi farò sapere le mie impressioni...
    Androidiano VIP L'avatar di giupa87
    Gela, Italy, Italy
    Galaxy Nexus
    Ringraziato 225 volte in 194 Posts
    Importanti novità in arrivo
    ChangeLog
    Coming:
    1) hide statusbar battery icon
    2) dialer: prevent touch from sleeping with touchwake enabled kernel when screen is off (base on AOKP)
    3) Power Shutter NPE fix (cm)
    4) Force highend GFX option
    5) dalvik and libcore leaks (AOSP)
    6) stock Recents panel view: force clear caches on longclick
    7) Active Display Rework
    - fix derppy pocket mode
    - partially fix unlock action
    (so far I did work out a workaround that need to reset lockscreen state. ie. you will get a normal lockscreen view in transition. )
    - add back sun light mode and turn screen off option.
     Security Settings: Add multi user enable switch.
  4. #43
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    Cavolo se macinano, bene bene...me gusta sta rom...
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  5. #44
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da giupa87 Visualizza il messaggio
    ChangeLog 23th Feb 2014 - ver. 2.8.1
    added
    8) Security Settings: Add multi user enable switch.
    note: since there are numerous option not yet fix with multi user support. FC are expected with multi user.
    9) Fix Statusbar Carrier Label option doesn't stick with reboot.
    10) ramdisk tweaks based on DirtyV picks (portion done by franciscofranco, ak, boype & osm0sis + Franco's Dev Team).
    Quote Originariamente inviato da dado70 Visualizza il messaggio
    new buils is out !!!
    DOWNLOAD in OP
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  6. Il seguente Utente ha ringraziato morfances per il post:
    giupa87 (23-02-14)
  7. #45
    Ultima (spero) domanda pre-flash :-D
    Questa rom permette il blacklist delle chiamate?
    EDIT: si c'è l'ha, in fase flash!
    Consigliare kernel stock o altro?
    Ultima modifica di grotesque; 23-02-14 alle 00:24
  8. #46
    LG G3
    Quote Originariamente inviato da grotesque Visualizza il messaggio
    Io la sto provando con il kernel stock e va una meraviglia... Son proprio contento di come si comporta su tutto..
  9. #47
    Forlimpopoli (FC)
    Forza ragazzi che questa è la rom giusta, dai dai... ;-D
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  10. #48
    Flashato, andato tutto ok... ma da un momento all'altro problemi con connessione ai server google! Icona wifi arancione, e sembra non andare nemmeno tipo app del giorno o una qualsiasi app che si deve collegare...
    Ultima modifica di grotesque; 23-02-14 alle 03:08
  11. #49
    Gela, Italy, Italy
    Galaxy Nexus
    A me dopo il flash va in bootloop
    Edit: chi é riuscito ad aggiornare si trova in art o dalvick? Credo che il problema sia relativo a chi é in art. Come carico un po il telefono passo a dalvick e riprovo a flashare
    Avevo ragione. Questa build con art va in bootloop. Passato a dalvik e tutto è andato liscio
    Ultima modifica di giupa87; 23-02-14 alle 13:12
  12. #50
    Androidiano L'avatar di street21
    Samsung Galaxy Nexus
    Ciao ragazzi ho questa rom da un mese e ieri (finalmente) ho deciso di usare qualche tema ma ho notato che non mi cambia l'icona della batteria. Ho provato diversi temi ma rimane sempre la solita stock. Come posso risolvere ?
