Pagina 21 di 93 primaprima ... 1119202122233171 ... ultimoultimo
Visualizzazione dei risultati da 201 a 210 su 925
[ROM][4.3][Linaro] ♦ PURITY ♦
  1. #201
    LG Nexus 5 black,32 GB
    Ringraziato 158 volte in 151 Posts
    Quote Originariamente inviato da Aetos Visualizza il messaggio
    # Purity v5.6
    Known bugs:
    Flipboard rendering bug fixed
    Browser fc fixed
    Wrong data usage fixed
    Build:
    - c11 support
    - [ARM] Remove WITH_JIT guards
    Dalvik:
    - Revert latest JIT commits due to data usage bug.
    Frameworks_av:
    - Noise will be heard if audio sample rate not matched with audio track
    - libstagefright: support for disabling buffer metadata
    Frameworks_base:
    - Bye, bye Talk. Welcome Hangouts (1/2)
    - Pie controls: Fix event handling on chained input filters
    - Lockscreen : Add custom background overlay
    - NavRing : Fix FC on rotate
    - Pie controls: Fix flickering nav bar in full screen
    - Pie controls: Catching activation corner cases
    - Fix the flipping animation sometimes being played when pulling the quick
    - Check themes of current user, not user 0.
    - Finally fix incorrect flipping to quick settings.
    - Fix incorrect fragment animation used for hiding fragments
    - change "next" to "done" in minute IME option under 24-hour format
    - Fixing crash in PhoneNumberUtils getNumberFromIntent
    - Fix NPE in NavigationBarView during bugreport
    - Fix theme provider crashing for non-primary user.
    - Don't assume any ringtone is present on external storage.
    - AssetRedirectionService: Check for permissions before running dump()
    - Lockscreen : Fix widgets disabled
    - Fix mobile data button in power widget.
    - Avoid unnecessary FindClass("java/lang/String").
    - Properly rotate full [-pi, +pi] orientation range if available
    - framework:base: iterator error in singletone provider
    - - Electrobeam settings support (CRT on/off)
    Frameworks_native:
    - provide overrides for hwui memory limits for xxhdpi phones
    Libhardware_legacy:
    - Increase stream mute time
    Mms:
    - Fix up receiver declaration.
    - Fix 'vibrate on call' option.
    - Some cleanup.
    - Mms: Delay unicode stripping from a message
    Phone:
    - PhoneApp: Initialize ToneGenerator when needed
    - NetworkSettings: Cannot dismiss progress dialog sometimes.
    - Phone: Ignore touch during network operators search
    - Fix a Cursor leak
    Settings:
    - We have Hangouts now!
    - Notification Light: Fix apps with same name not showing up
    - Electrobeam settings (CRT on/off)
    Purity_v5.6_mako.zip
    In download
    Ragazzi, appurato che questa è una rom ottima ( la uso ormai da...ho perso il conto!!), chi mi sa dire quale è il kernel migliore? Monto l'ultimo del semaphore ormai da più settimane ma ultimamente noto un riscaldamento un pò più alto del dovuto. Cosa mi consigliate?
  4. #203
    Androidiano VIP L'avatar di Pomponio2196
    Pennadomo (CH)
    Nexus 4
    Ringraziato 335 volte in 262 Posts
    Quote Originariamente inviato da lorisdodaro Visualizza il messaggio
    La mia stessa domanda,l'ak è fermo da un po per riparazione del telefono,non so come possa essere il franco supercharged
    Telefono: Nexus 5
    Rom: The PureNexus Project
    Kernel: Blue_spark r16
    Gapps: TK Gapps Pico
    <--Se in qualche modo ti ho aiutato,premi il tasto THANKS
  5. #204
    Quote Originariamente inviato da Pomponio2196 Visualizza il messaggio
    Il franco supercharged non l ho mai sentito. È una versione nuova del franco?
  6. #205
    Pennadomo (CH)
    Nexus 4
    E' una versione rivisitata del franco
    Telefono: Nexus 5
  7. #206
    E in cosa si differenzia dal classico franco kernel?
  8. #207
    Pennadomo (CH)
    Nexus 4
    https://www.androidiani.com/forum/mo...co-kernel.html non so nemmeno io,forse alcune ottimizzazioni,questo è il thread se ti interessa
    Telefono: Nexus 5
  9. Il seguente Utente ha ringraziato Pomponio2196 per il post:
    lorisdodaro (21-06-13)
  10. #208
    Ho scelto. Ho messo il franco kernel. L'ultima nightly. Vediamo, non lo provo ormai da un bel pò
  11. #209
    Pennadomo (CH)
    Nexus 4
    sennò un'ottima alternativa è il purified r44,basato sul franco e con ottimizzazioni di altri kernel
    Telefono: Nexus 5
  12. #210
    Capito. Ora testerò , nuovamente, il franco. Poi farò i dovuti confronti e se vedo che era meglio il semaphore, ne proverò degli altri
  13. Il seguente Utente ha ringraziato lorisdodaro per il post:
    Pomponio2196 (21-06-13)
