Visualizza i risultati del sondaggio: State provando questa ROM ?
Chi ha votato
13. Non puoi votare questo sondaggio
  • Si , aggiorno ogni nightly della AOSPAL
    7 53.85%
  • No, ma seguo gli aggiornamenti pensando di usarla in futuro
    5 38.46%
  • No , non è una Rom interessante
    1 7.69%
Pagina 15 di 21 primaprima ... 51314151617 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 203
[AOSPA4][KITKAT][SABERMOD4.8] ParanoidSaberDroid - AOSPAL
  1. #141
    Si quello, visto che no hanno fixato, nella rom, il consumo eccessivo do systemui, con quel kernel la batteria è infinita
    Androidiano VIP L'avatar di fabribasi
    Nexus 4
    Ringraziato 31 volte in 31 Posts
    Con quel kernel gire il touch control?
    Paranoid 3.99RC1 Franco kernel
  4. #143
    Nuovo aggiornamento! March 26th, 2014 | PA 4.2 BETA-2
    PA (Updated to the latest 4.2-BETA-2)
    Pie had finally come to AOSPALI! To enable it, pull the quick settings and tap on immersive mode. You'll be given an option to either use pie or immersive to navigate. It can be reset through Settings -> Backup & Reset -> Reset Preferences just like PA's style
    AppOps: Improve listing of apps
    DownloadNotifier: Normal notification for singles
    Custom lockscreen background
    Quick Settings: Sound tile
    SystemUI: Set Status bar opaque during drawer pulldown on tablets only
    Features:
    Lockscreen Widgets: Disable keyguard widget frame (Security -> Widgets)
    More Lockscreen Colors (Remix Setttings -> Lockscreen -> Lockscreen Style)
    Removed Quiet Hours.
    Sound pack feature is currently been removed from the Sound Settings due to a problem
    Improvements:
    Enabled memory optimization flag
    New Remix Settings icon
    Reverted additional white colors commits, will stay on stock Google style.
    ROM file name method had been changed
    Lockscreen Blur: Disable if music is playing
    Others
    Moved screen record settings to Remix Settings
    Added PSD version, SaberMod toolchain version (Both ROM and Kernel) into About Device
    Modified AOSP's Browser from CM
    [/QUOTE]
    Build is up on Andromirror -> see OP
    Mirror -> http://d-h.st/5pv
  5. #144
    La provo e vedo se hanno fixato com.systemui
  6. #145
    Androidiano L'avatar di sirius002
    Nexus 4
    Quote Originariamente inviato da dega95 Visualizza il messaggio
    ho provato un pò questo kernel ma non mi ha dato molta fiducia, con governor interactive e ondemand consuma molto durante l'uso del cell, con altri governor lagga....sono tornato al hellscore che con frequenza minima 81 e gov weathly ha più o meno gli stessi consumi a riposo e zero lag
  7. #146
    Che strano, a me è perfetto
  8. #147
    Nexus 4
    Ci sono importanti novità nell'ultima release?
  9. #148
    Le cose scritte li ma di sostanzioso secondo me è migliorata la batteria
  10. #149
    NexusZero
    Il pie è la novità principale ma non si può ancora personalizzare.. Poi molte cose sono tornate holo blue, cosa che a me non piace
  11. #150
    Cioè? Da me no
