Pagina 185 di 195 primaprima ... 85135175183184185186187 ... ultimoultimo
Visualizzazione dei risultati da 1,841 a 1,850 su 1946
Monitorare il Consumo della Batteria
  1. #1841
    Bologna
    Samsung Galaxy Note 4 Gold
    Ringraziato 31 volte in 25 Posts
    Ciao a tutti questo è il mio terribile log che ho riscontrato oggi:
    2012/01/23 09:38:02,-4mA,94%,4.123V
    2012/01/23 09:44:59,-9mA,94%,4.123V
    2012/01/23 09:48:31,-9mA,94%,4.123V
    2012/01/23 09:53:00,-63mA,94%,4.079V
    2012/01/23 10:01:19,-66mA,93%,4.094V
    2012/01/23 10:03:36,-63mA,93%,4.089V
    2012/01/23 10:04:59,-63mA,93%,4.089V
    2012/01/23 10:14:59,-66mA,92%,4.089V
    2012/01/23 10:15:00,-66mA,92%,4.089V
    2012/01/23 10:17:21,-66mA,91%,4.079V
    2012/01/23 10:19:00,-72mA,91%,4.079V
    2012/01/23 10:20:01,-66mA,91%,4.079V
    2012/01/23 10:23:03,-66mA,91%,4.079V
    2012/01/23 10:31:21,-66mA,90%,4.067V
    2012/01/23 10:33:39,-66mA,90%,4.067V
    2012/01/23 10:44:37,-67mA,89%,4.055V
    2012/01/23 10:46:23,-124mA,89%,4.055V
    2012/01/23 10:49:35,-71mA,89%,4.055V
    2012/01/23 10:50:35,-66mA,88%,4.05V
    2012/01/23 10:53:02,-66mA,88%,4.05V
    2012/01/23 11:01:23,-64mA,87%,4.04V
    2012/01/23 11:03:42,-64mA,87%,4.04V
    2012/01/23 11:05:35,-66mA,87%,4.04V
    2012/01/23 11:14:59,-67mA,86%,4.03V
    2012/01/23 11:16:13,-67mA,86%,4.03V
    2012/01/23 11:17:14,-67mA,86%,4.03V
    2012/01/23 11:19:36,-66mA,85%,4.026V
    2012/01/23 11:20:36,-66mA,85%,4.026V
    2012/01/23 11:23:03,-74mA,85%,4.026V
    2012/01/23 11:24:10,-76mA,85%,4.026V
    2012/01/23 11:25:10,-143mA,85%,4.026V
    2012/01/23 11:26:10,-148mA,85%,4.026V
    2012/01/23 11:31:24,-66mA,84%,4.016V
    2012/01/23 11:33:43,-67mA,84%,4.016V
    2012/01/23 11:35:36,-67mA,84%,4.016V
    2012/01/23 11:44:02,-67mA,83%,4.006V
    2012/01/23 11:45:03,-107mA,83%,4.006V
    2012/01/23 11:47:18,-64mA,83%,4.006V
    2012/01/23 11:49:37,-67mA,82%,4.001V
    2012/01/23 11:50:37,-64mA,82%,4.001V
    2012/01/23 11:53:03,-64mA,82%,4.001V
    2012/01/23 11:55:16,-73mA,82%,4.001V
    2012/01/23 12:01:24,-66mA,81%,3.991V
    La ROM che utilizzo è la Er3Bus 3.5... Qualcuno sa quale potrebbe essere il problema? Con la ROM che montavo precedentemente (CORE Droid 9.2) non avevo questi problemi. Potrebbe essere un problema di kernel?
    Androidiano VIP L'avatar di savioonline
    Apr 2011
    Bari
    Ringraziato 70 volte in 63 Posts
    E' il classico log di chi ha l'opzione "prestazioni wi-fi migliori" attivata... non è che ce l'hai attivo?
  4. #1843
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da superlegno Visualizza il messaggio
    come si fa a saperlo?
    senza nessuna informazioni a parte il log non è possibile dire niente,si puo solo tirare a indovinare
    il log è stato fatto nella maniera adeguata' ?
    questo log riguarda la sola rom appena installata ? oppure è gia piena di applicazioni.tweacks,patch,impostazioni,ecc..ecc.. ecc...?
    hai fatto un log a rom appena installata per confrontarlo con il log della rom configurata?
  5. #1844
    Bologna
    Quote Originariamente inviato da savioonline Visualizza il messaggio
    Ho appena controllato ed infatti avevo attivato prestazioni Wi-fi migliori.... Ma quindi ciò comporta un aumento così esagerato nei consumi?
  6. #1845
    Apr 2011
    Bari
    Ebbene si, ci son passato anch'io... dai soliti 3mA/7mA passa ai 70 circa
  7. Il seguente Utente ha ringraziato savioonline per il post:
    superlegno (23-01-12)
  8. #1846
    Bologna
    La ROM è senza alcuna patch o tweak ho solo installato quelle applicazioni che già avevo nella Rom precedente e che non inficiavano sulle prestazioni della batteria. È per questo che mi chiedevo se non fosse un problema di kernel.
    p.s. Avevo però attivo prestazioni wi-fi migliori...
    Ultima modifica di superlegno; 23-01-12 alle 16:06
  9. #1847
    Dec 2009
    Rimini
    La ROM è senza alcuna patch o tweak ho solo installato quelle applicazioni che già avevo nella Rom precedente e che non inficiavano sulle prestazioni della batteria. Avevo però attivo prestazioni wi-fi migliori...
    in ogni caso avevi fatto un log senza installare applicazioni e toccato alcuna impostazione?
    è l'unico modo per risalire a eventuali "problemi"
  10. #1848
    Bologna
    No non l'avevo fatto comunque ho fatto un backup della rom pulita quindi potrei ripristinarlo e provare .. oppure basta che cancelli quella decina di applicazioni che ho installato e riprovi?
  11. #1849
    Bologna
    Grazie mille savioonline ho rifatto il log con le prestazioni wi-fi migliori disattivate ed ho consumato appena il 2% di batteria in 2 ore e mezza con assorbimento in mA di 2/5.
  12. Il seguente Utente ha ringraziato superlegno per il post:
    savioonline (23-01-12)
  13. #1850
    Senior Droid L'avatar di i-green
    Samsung A7 (2018)
    Ringraziato 33 volte in 26 Posts
    Ragazzi aiutate anche me?
    Ieri ho installato ciò che leggete nella mia firma (tranne la RADIO che era quella originale).
    Purtroppo non ho pensato a fare un log della ROM pulita. Comunque dopo il flash della ROM ho installato:
    SMS Backup+
    RIL Infos
    ASTRO
    battery calibration
    CurrentWidget
    XDA
    Ho calibrato la batteria come nella guida in prima pagina lasciando caricare il DHD tutta la notte.
    Il log l'ho fatto con wifi attivo (prestazioni migliori disattivo), connessione dati sempre attiva, ho lanciato il sync e l'ho messo in stand by per 2 ore (sono arrivati 2 sms in questo lasso di tempo ma ho lasciato il DHD in stand-by).
    Questo il pessimo log:
    2012/01/24 09:32:03,-14mA,85%,3.974V
    2012/01/24 09:33:03,-107mA,85%,3.974V
    2012/01/24 09:34:03,-18mA,85%,3.974V
    2012/01/24 09:35:07,-62mA,85%,4.018V
    2012/01/24 09:36:07,-103mA,85%,4.018V
    2012/01/24 09:37:07,-93mA,85%,4.018V
    2012/01/24 09:38:38,-9mA,84%,4.008V
    2012/01/24 09:40:45,-5mA,84%,4.033V
    2012/01/24 09:42:21,-9mA,84%,4.033V
    2012/01/24 09:43:50,-11mA,84%,4.033V
    2012/01/24 09:44:50,-11mA,84%,4.033V
    2012/01/24 09:45:50,-5mA,84%,4.033V
    2012/01/24 09:47:50,-28mA,84%,4.033V
    2012/01/24 09:51:33,-8mA,84%,4.033V
    2012/01/24 09:53:37,-10mA,84%,4.033V
    2012/01/24 09:57:57,-17mA,84%,4.021V
    2012/01/24 09:59:18,-7mA,84%,4.021V
    2012/01/24 10:06:43,-5mA,84%,4.021V
    2012/01/24 10:07:43,-47mA,84%,4.021V
    2012/01/24 10:18:40,-11mA,83%,4.028V
    2012/01/24 10:23:37,-5mA,83%,4.028V
    2012/01/24 10:27:57,-7mA,83%,4.028V
    2012/01/24 10:36:46,-164mA,83%,4.028V
    2012/01/24 10:38:38,-11mA,83%,4.028V
    2012/01/24 10:48:41,-10mA,83%,4.028V
    2012/01/24 10:53:36,-5mA,83%,4.028V
    2012/01/24 10:57:58,-8mA,83%,4.028V
    2012/01/24 11:08:01,-5mA,83%,4.028V
    2012/01/24 11:18:40,-5mA,83%,4.028V
    2012/01/24 11:23:37,-8mA,82%,4.018V
    2012/01/24 11:27:57,-5mA,82%,4.018V
    2012/01/24 11:38:00,-15mA,82%,4.018V
    2012/01/24 11:48:39,-17mA,82%,4.018V
    2012/01/24 11:50:46,-6mA,82%,4.018V
    2012/01/24 11:51:46,-236mA,82%,4.018V
    2012/01/24 11:52:46,-140mA,82%,4.018V
    2012/01/24 11:53:46,-189mA,81%,3.96V
    2012/01/24 11:54:46,-191mA,81%,3.96V
    2012/01/24 11:55:46,-191mA,81%,3.96V
    2012/01/24 11:56:46,-143mA,80%,3.947V
    2012/01/24 11:57:46,-229mA,80%,3.933V
    2012/01/24 12:00:54,-40mA,80%,3.933V
    2012/01/24 12:01:54,-27mA,80%,3.933V
    2012/01/24 12:03:54,-27mA,80%,3.933V
    2012/01/24 12:04:54,-187mA,80%,3.933V
    2012/01/24 12:05:54,-47mA,79%,3.943V
