Pagina 48 di 168 primaprima ... 3846474849505898148 ... ultimoultimo
Visualizzazione dei risultati da 471 a 480 su 1673
[ROM]MIUI's tra semplicita' e potenza[2.3.7c Stabile][2.1.20 Weekly]
  1. #471
    Androidiano VIP L'avatar di ilbi
    Jan 2011
    Pescara
    Desire HD
    kernel versione 6.0.1 Lordmod
    16-07-2011 LorDmod UE 6.0.1
    fixed issues when installing apps from market and/or moving them to SD
    15-07-2011 LorDmod UE 6.0
    increased max voltage for VDD to 1550 mV
    implemented Simple I/O scheduler (Vio is still default)
    added option to chose other I/O schedulers in No-Frills (BFQ, Simple, V(r) so everybody is happy)
    tweaked brazilianwax, so hopefuly will scale more freqs
    tweaked charging to slowly "overcharge" more than 2 hours after it reaches 100%
    tweaked cacheV7 - v7_coherent_user_range from the galaxy s kernel
    tweaked BFS a little (for BFS kernel off course)
    More increased VM_MAX_READAHEAD from 512 -> 4096 kb
    added MD driver backport from 2.6.36.1 kernel (by Imoseyon)
    added BLOCK driver backported from 2.6.36.1 kernel (by Imoseyon)
    added MTD driver backported from 2.6.36.1 kernel (by Imoseyon)
    added I2C driver backported from 2.6.36.1 kernel (by Imoseyon)
    added new WORKQUE code from 36.1 and rest of kernel patched dangerously by Imoseyon - modified governors by LorD ClockaN
    added CPUIDLE code from 3.0rc6 kernel (by Imoseyon)
    added CPUFREQ code from 3.0rc6 kernel (by Imoseyon) - modified by LorD ClockaN
    added Bluetooth code from 3.0rc6 kernel (by Imoseyon)
    2WCR kernel has new Callrecorder 1.0.26 alpha build 2 included
    Nuovo Market (V. 3.0.26)
    si installa come una comune apk
    Il nuovo market era stato indicato già a pag 45 invece il nuovo kernel come sarà? scusa, linux, ma non avevi detto che non si sarebbe più fatto un copia incolla da siti in inglese??
    HTC Desire HD S-off
    ROM: SmartDroid T-3.1 Sense 3.5|Tweaks|Scripts|App
    Kernel: 2.6.35.14-RCMIX3D-ACS-CR-V8
    Recovery: 4EXTRecovery Touch v1.0.0.3 Beta3
    Radio:12.65.60.29_26.14.04.28_M
    Ileana
    www.ilbarigelletti.org
    http://home.fotocommunity.it/ileana
    http://www.usefilm.com/photographer/14635.html
    http://www.ilbarigelletti.org/lanebbia/
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da ilbi Visualizza il messaggio
    questo è un changelog
    se non lo si capisce in inglese
    non lo si capisce neanche in italiano
  4. #473
    Sto testando il nuovo kernel 6.0.1 e sinceramente almeno nei giochi 3D pesi (Nova, DH2) mi sembra vada leggermente meglio il 5.1 (che me lo conferma anche nenamark che mi segna 40 fps contro i 43fps del 5.1) questo sulla miui 1.7.8 governor brazilianwax e freq. stock.
    Per il resto mi sembra che va più o meno come il 5.1...
  5. #474
    Nov 2010
    Ragazzi, utilizzo la miui da ieri, all'inizio diffidato anche per l'interfaccia in stile iphone 4, che a me non piace per niente, ma poi con launcher pro plus ho sistemato le cose e ora mi sto divertendo....una, cosa però:la batteria consuma troppo, l'ho acceso oggi alle 8.35 e all'una e mezza era già al 50% usandolo poco..... eppure ho flashato il fix batteria e il kernel lordmod consigliato...... Che dite?
    Inviato dal mio Desire HD usando Androidiani App
  6. #475
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    Quote Originariamente inviato da topy00 Visualizza il messaggio
    quale fix batteria?? l'apk da installare??
    hai settato la CPU??
    che kernel lordmod e'??
    a me con tutti i fix e il kernel lordmod 5.1 CFS va tutto bene!
    consumi inferiori ai -5mA in standby!!
    se proprio vedi che la situazione non cambia prova a reinstallare il fix o a riflashare la rom facendo un fullwipe (usa l'utility' backup integrata nella miui per non perdere i dati, la trovi nella cartella preimpostata "strumenti")
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
  7. #476
    Jan 2011
    Scusate non riesco a trovare le gapps adatte alla miui potete dirmi quali prendere?
  8. #477
    Dec 2009
    Rimini
    Quote Originariamente inviato da sbn73 Visualizza il messaggio
    evitiamo di fare le stesse domande quando
    oltretutto è appena stato chiesto
  9. #478
    Dopo aver smanettato per una mezza giornata con la miui mi ritengo molto soddisfatto certo per levare lo stile iphone ce né voluto ma adesso molto fluida direi innovativa sotto molti aspetti e per adesso la durata della batteria è ottima
  10. #479
    Che differenza c'è tra la base e la Squeezly che trovo su XDA?
  11. #480
    [QUOTE=cesco89;558660
    [/QUOTE]
    Perdonami, ma quali sono tutti i fix da installare?
