Ho messo in download la virtous doubleshot e dal changelog promette bene una sense 3 molto ottimizzata e performante a più tardi per gli aggiornamenti ;) aosp vs sense la lotta continua
in 5 ore e 20 minuti 2% ;)codice:2011/07/11 04:25:35,-1mA,20%,3.757V
2011/07/11 04:35:37,-1mA,20%,3.757V
2011/07/11 04:39:27,-2mA,20%,3.757V
2011/07/11 04:50:44,-1mA,20%,3.757V
2011/07/11 04:50:44,-5mA,20%,3.757V
2011/07/11 04:55:44,-5mA,20%,3.757V
2011/07/11 05:05:46,-5mA,20%,3.757V
2011/07/11 05:09:28,-5mA,20%,3.757V
2011/07/11 05:14:53,-5mA,20%,3.757V
2011/07/11 05:19:01,-50mA,19%,3.713V
2011/07/11 05:19:01,-180mA,19%,3.711V
2011/07/11 05:25:42,-180mA,19%,3.711V
2011/07/11 05:25:42,-180mA,19%,3.752V
2011/07/11 05:29:55,-183mA,19%,3.711V
2011/07/11 05:31:30,-183mA,19%,3.711V
2011/07/11 05:31:30,-9mA,19%,3.755V
2011/07/11 05:33:53,-182mA,19%,3.725V
2011/07/11 05:39:29,-1mA,19%,3.757V
2011/07/11 05:39:30,-1mA,19%,3.757V
2011/07/11 05:49:32,-5mA,19%,3.757V
2011/07/11 05:55:43,-12mA,19%,3.757V
2011/07/11 06:05:45,-15mA,19%,3.757V
2011/07/11 06:09:30,-1mA,19%,3.757V
2011/07/11 06:19:33,-9mA,19%,3.757V
2011/07/11 06:25:43,-1mA,19%,3.757V
2011/07/11 06:28:21,-5mA,19%,3.757V
2011/07/11 06:38:24,-5mA,19%,3.757V
2011/07/11 06:40:42,-10mA,19%,3.757V
2011/07/11 06:40:42,-5mA,19%,3.757V
2011/07/11 06:50:45,-1mA,19%,3.757V
2011/07/11 06:55:43,-5mA,19%,3.757V
2011/07/11 07:05:46,-5mA,19%,3.757V
2011/07/11 07:09:35,-5mA,19%,3.757V
2011/07/11 07:15:12,-1mA,19%,3.757V
2011/07/11 07:19:20,-181mA,18%,3.706V
2011/07/11 07:25:42,-1mA,18%,3.706V
2011/07/11 07:29:44,-5mA,18%,3.706V
2011/07/11 07:34:11,-180mA,18%,3.706V
2011/07/11 07:39:37,-1mA,18%,3.706V
2011/07/11 07:49:39,-5mA,18%,3.706V
2011/07/11 07:55:43,-5mA,18%,3.706V
2011/07/11 08:05:46,-5mA,18%,3.706V
2011/07/11 08:09:38,-3mA,18%,3.706V
2011/07/11 08:20:44,-5mA,18%,3.706V
2011/07/11 08:25:42,-24mA,18%,3.706V
2011/07/11 08:31:07,-5mA,18%,3.706V
2011/07/11 08:39:40,-7mA,18%,3.706V
2011/07/11 08:44:48,-5mA,18%,3.706V
2011/07/11 08:44:49,-5mA,18%,3.706V
ogni tanto c'è un picco di consumo che penso sia per il sync Facebook e Google, però anche così la batteria non ne risente troppo per fortuna.
Hai flash qualche script uv di lordmod?
il consumo è ottimo anche se le ore non sono 5.20 ma 4.20 e il consumo
è il 3% ; il test andrebbe fatto a batteria carica ...
comunque è un dato eccellente per qualunque rom dal momento che rimane sotto l'1% ora
se si considera il dato pieno leggibile che va dalle 5.19 quando scatta il 19% e le 7.19 quando scatta il 18% il consumo è esattamente 0.5% ora
meglio non puo andare se confermato dal test con batteria carica...
Che resta non troppo diverso dalla mia Virtuous xD solo che il max sleep oc era ancora ad 806 :)
La norma fare 0,5% l'ora??Quote:
diciamo che per molte sense rappresenterebbe la norma
ma per le AOSP è una vera conquista che dimostra che ormai
ce la si gioca ad armi pari anche sui consumi....
La norma era 1% l'ora... mi sembra che neanche mem che ha i consumi migliori al mondo tra i possesso del desire hd abbia mai postato un log da 0,5% l'ora netti (con le sense)... come confermano anche i suoi post nel 3d della hydorgen questa aosp supera (e non di poco) le sense per quanto riguarda la durata della batteria... poi per il resto non so...(anche se secondo me il kernel fa la sua parte non solo la rom)
Ok..ma il discorso di linux era una proporzione..a parità di processi attivi, la dense va tranquilla ma la aosp non si muoverebbe..quindi anche se la aosp consuma meno, è solo perché ha meno processi attivi e non potrebbe essere in grado di attivarne altri..ergo, le sense consumano di meno e sono più performanti..e ha ragione ragazzi..da vendere;-) all'atto pratico ovviamente consuma meno un aosp ma solo in apparenza e in condizioni di disuguaglianza rispetto alla sense..
Inviato dal mio Desire HD usando Tapatalk
Si ma se avere più processi attivi non porta vantaggi sensibili la sense sarà anche più "bella" perché ha tanti processi attivi e consuma poco ma la cosa è in verità abbastanza inutile...almeno per la maggior parte dell'utenza.. il discorso dei processi ha senso finché la rom riesce ad eguagliare la durata della batteria delle aosp. Se è così la maggior parte degli utenti può scegliere a parità di batteria di optare per la rom che gestisce più processi anche se torno a ripetere che a mio parere pochi si accorgono di questo dato. Altrimenti nel momento in cui la.sense deve sacrificare la durata della batteria (che è in realtà il vero dato che muove il mercato e la scelta del singolo) o si migliora la rom o le fai gestire meno processi. Se no è ovvio che la gente inizia a preferire le aosp...
Anche l'occhio vuole la sua parte, altrimenti tante cose scritte in questi forum non avrebbero senso. Ci sono sempre i compromessi tra performance ed estetica.
Gli effetti della sense 3 ragazzi vengono da un altro pianeta anche se la batteria dovesse durare un'ora in meno a mio parere.
DHD+Rom Virtuous 1.27+Kernel stock+Tapatalk
