Pagina 12 di 28 primaprima ... 2101112131422 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 272
[ROM][S4] SourcE | Audio quality | Fast | Smooth | [3.16.401.9] base
  1. #111
    Androidiano VIP L'avatar di babybrustenberg
    Nov 2009
    Nel Paese Delle Meraviglie
    Ringraziato 55 volte in 50 Posts
    Quote Originariamente inviato da ultimo125 Visualizza il messaggio
    Ma hai messo qualche kernel mod, tipo elementalx o bulletproff ?
    Perché questi hanno delle features x accedere lo schermo, tipo doppio tap sul tasto home, oppure strisciando da sinistra a destra su i tasti soft.
    Si ho il kernel elemental... Dove devo andare per cambiare le impostazioni??
    HTC ONE S S4 NO BRAND
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    Quote Originariamente inviato da babybrustenberg Visualizza il messaggio
    NOTES:
    Configuration
    Your choices in the Aroma installer are used to build a configuration file. The config file is located at /etc/elementalx.conf. You can edit this file to change kernel settings. Whatever is set in this file will take effect when the device is booted (unless other scripts or apps interfere!)
    The settings can be changed by editing /etc/elementalx.conf and rebooting. Advanced users can apply settings on the fly by running /etc/init.d/99elementalx as root.
    There is no need to edit /etc/init.d/99elementalx. All settings are configured in /etc/elementalx.conf.
    If settings are not sticking, make sure the file permissions for /etc/init.d/99elementalx are set to execute. Every time the settings are applied, a log file is created at /data/local/tmp/elementalx-kernel.log. Problems can be diagnosed by looking at the log file.
    Please check to see if any /etc/init.d scripts or apps are interfering with your settings If you're on ViperXL, make sure your settings in Venom Tweaks are the same as the ones in /etc/elementalx.conf (for example, sweep2wake settings)
    Sweep2Wake
    Sweep2wake allows you to wake up your device by swiping your finger across the capacitive buttons from left to right. Swiping from right to left will put it back to sleep (sweep2sleep). There are now options for sweep2wake/sweep2sleep, sweep2sleep only, and disabled. If you use ViperXL, make sure to enable sweep2wake in Venom Tweaks. Note that in Venom Tweaks, the sweep2sleep only option can be selected by choosing Enable (no buttons backlight).
    DoubleTap2Wake
    DoubleTap2Wake (DT2W) allows you to wake the device by double tapping the capacitive buttons.
    /sys/android_key/doubletap2wake
    0=disabled
    1=enable doubletap2wake using back button
    2=enable doubletap2wake using home button
    3=enable doubletap2wake using recent apps button
    Button Light Notification
    With Button Light Notification (BLN), the capacitive buttons will blink on and off when you have a new notification. You can edit /etc/elementalx.conf to change the setting on boot.
    /sys/class/leds/button-backlight/bln
    0 = disabled
    1 = BLN enabled
    Il tuo problema dovrebbe essere il DoubleTap2Wake, ma potrebbe dipendere anche dallo Sweep2Wak se non li usi puoi disabilitarli entrambi, se non ti riesce, forse conviene riflashare il kernel, e disabiltarli in fase di installazione !!!
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
  4. Il seguente Utente ha ringraziato ultimo125 per il post:
    babybrustenberg (10-08-13)
  5. #113
    Nov 2009
    OK.. Li ho attivi entrambi... Solo che il ho flashato il kernel con imageGUI per cui non mi HD fatto scegliere queste impostazioni... come le posso cambiare ora? Non posso editare i file di cui si parla??
    Ultima modifica di babybrustenberg; 10-08-13 alle 17:19
  6. #114
    Brindisi (Prov)
    new "HTC ONE M8"
    OK.. Li ho attivi entrambi... Solo che io ho flashato il kernel con imageGUI per cui non mi ha fatto scegliere queste impostazioni... come le posso cambiare ora? Non posso editare i file di cui si parla??
    infatti se hai flashato tramite FlashImageGUI ... giustamente è impostato tutto come da defoult, ed i files da editare non sono presenti ... ora da Recovery flasha il file zip dell'ElementalX
    e durante l'installazione stai attenta a scegliere di Disabilitare le Funzioni DoubleTap2Wake ed Sweep2Wak
    mi pare che in automatico non funzionerà nemmeno il Button Light Notification
    EDIT: per tutti coloro che hanno il terminale in S-ON
    la procedura per installare un Kernel come ElementalX o Bulletproff
    è identica all'installazione di una nuova ROM
    e prevede il Flash del boot.img da Fastboot o FlashImageGUI
    più il Flash dello zip da Recovery.
    Ultima modifica di ultimo125; 10-08-13 alle 17:41
  7. Il seguente Utente ha ringraziato ultimo125 per il post:
  8. #115
    Nov 2009
    OK... Devo solo andare in recovery e flashare il pacchetto o devo fare anche qualche wipe??
  9. #116
    Brindisi (Prov)
    new "HTC ONE M8"
    si da Recovery ...
    per ElementalX dal Flash parte Aroma Installer è mi pare che faccia Wipe in automatico, e te lo chiederà anche alla fine
    tu comunque fai Wipe Cache e Dalvik Cache da recovery, prima ed anche alla fine, ho provato personalmente non gli fà male !!!!
    PS. ho aggiunto un EDIT al Post precedente !!!!
  10. Il seguente Utente ha ringraziato ultimo125 per il post:
    babybrustenberg (11-08-13)
  11. #117
    alexis77
    Se vuoi anche il BLN funzionante attiva almeno il DoubleTap2wake
  12. Il seguente Utente ha ringraziato alexis77 per il post:
    ultimo125 (10-08-13)
  13. #118
    Ringraziato 40 volte in 30 Posts
    sinceramente non ho problemi di nessun tipo ora con questa rom
  14. #119
    Nov 2009
    si da Recovery ...
    Perfetto... Flashato di nuovo il kernel da fastboot e seguito l'installazione con aroma... Tutto OK!!! grazie ragazzi!!!! Credo che terrò questa ROM per moooooolto tempo!!!!
  15. Il seguente Utente ha ringraziato babybrustenberg per il post:
    ultimo125 (11-08-13)
  16. #120
    Brindisi (Prov)
    new "HTC ONE M8"
    Ok ... tieni sempre aggiornato il thread con nuove impressioni, ed eventuali consigli.
    Grazie.
    Ultima modifica di ultimo125; 11-08-13 alle 16:24
