Pagina 150 di 174 primaprima ... 50100140148149150151152160 ... ultimoultimo
Visualizzazione dei risultati da 1,491 a 1,500 su 1735
  1. #1491
    Androidiano L'avatar di nini6616
    trieste
    note 8
    ok ragazzi ce lo fata finalmente... domani facio un topic pulito sia per la pandora che per la slim plus
    by nini
    Feb 2014
    These are just nightly builds as far as I can see, are they stable enough?
    Also, I've installed CM10.1 because of this theme https://play.google.com/store/apps/d...crystal2&hl=en, it's one of the best I have ever seen
  4. #1493
    Senior Droid L'avatar di l30n4rd0
    Terni/Roma
    HUAWEI Ascend G330 (U8825-1)
    Ringraziato 72 volte in 53 Posts
    Quote Originariamente inviato da djuka Visualizza il messaggio
    CM11 is nightly and I think probably never release a "stable" version. Also I use cm11 and it's more stable then other ROM. Camera works fine, no problems with storage unit and new feature are releasing for camera in cm11 (buttons control like volume keys for zoom e power button to shot).
    I tried this theme for you on cm11 and it seems to work fine: an issue only one time when I selected theme (systemui force closed), but after it works.
    Finally...
    You can install CM11 for G330 and your favourite theme!
    Smartphone: Huawei Ascend G330 (U8825-1)
    ROM: CyanogenMod 11
    Recovery: TWRP 2.7.1.0
    Root: Done
    Unloock bootloader: Done
    Tablet: Nexus 7 3G 32 GB
    ROM: CyanogenMod 11 for Tilapia
    Recovery: TWRP 2.6.3.0
    Root: Done
  5. #1494
    Feb 2014
    Thank you very much for the advice, I will definitely try it
  6. #1495
    Terni/Roma
    Good! You're welcome
    ROM: CyanogenMod 11
    Root: Done
    Root: Done
  7. #1496
    Cercatore di GnaGna L'avatar di Miciox
    Fantabosco
    Gio, G3, RN3P, iPhone 7
    Ringraziato 2,182 volte in 1,548 Posts
    Sorry, but the official and the only permitted language of the forum is Italian. Is forbidden to post there in other languages.
    Ultima modifica di Miciox; 19-02-14 alle 08:08
    Chi ti vede ti definisce solare, perché la foschia lieve della malinconia la vede solo chi si ferma un po’ a viverti.
  8. #1497
    Feb 2014
    This is a very oppressive rule.
    The whole point of Android, Linux, GPL and all the other similar stuff is openness and sharing.
    I could have used Google Translate to post my question but I think that is stupid.
    But I don't make the rules so you can delete this topic if you want to.
  9. #1498
    Androidiano di Riferimento L'avatar di Rz95
    Puglia, Prov. LE
    Samsung GALAXY SII plus
    Ringraziato 176 volte in 125 Posts
    Ottima questa cyano 11 forse meglio della stock 4.0.4 ho riscontrato solo alcuni problemi e cioè nella schermata home non riesco ad aggiungere altre schermate, poi se organizzo le mie app in cartelle nella home dopo un riavvio non le trovo più nelle cartelle e infine avviando il telefono mi esce una notifica che dice che è stata rilevata la sim e chiede di riavviare ma riavviando la notifica si ripresenta ma premendo il tasto indietro la notifica scompare e funziona ugualmente la sim. Riscontrate anche voi questi problemi? Soluzioni?
  10. #1499
    Androidiano VIP L'avatar di wetito
    Reggio Emilia
    Samsung j5 2017
    Ringraziato 131 volte in 114 Posts
    Quote Originariamente inviato da donato95next Visualizza il messaggio
    usa nova. Per la sim ritieniti fortunato che ti esca quel messaggio! Il più delle volte se non esce non la legge
    è un problema che hanno praticamente tutte le ciano installate sul nostro terminale. L'unica rom senza nessun bug (almeno per quanto mi riguarda) è il porting della aosb fatto da prince
    _________________________________________
    Smartphone: Samsung J5 2017
  11. #1500
    Super Moderator L'avatar di paolov
    Galaxy S4 - Huawei P9 plus
    Ringraziato 4,344 volte in 3,048 Posts
    Sorry for posting in english but my italian sucks
    So, I've flashed CM 10.1 (kra1o5 r15) and most of the stuff works.
    However, there are a few problems and I was hoping that you could help me.
    1) Galery is not working
    2) Camera apps don't see ext-SD (tried stock app, Instagram and Zoom FX, same story).
    This might have something to do with me changing the settings for Link2SD so it can use internal SD as a second partition, but I'm not sure about it.
    Anyway, let me know what you think.
    Also, since I've did the backup of my phone calls and SMS with Huawei All Backup (and now I can't install it), how can I recover this?
    Grazie!
    La lingua ufficiale del forum è l'italiano. Puoi usare un traduttore.
    The official forum's language is Italian. You can use a translator.
